Ana içeriğe geç
SiriusXM Onyx Plus Case Replacement
Neye ihtiyacın var
  1. SiriusXM Onyx Plus Case Replacement, Case: adım 1, 1 resimden 1.
    • Wedge a plastic opening tool in between the case.
  2. SiriusXM Onyx Plus Case Replacement: adım 2, 3 resimden 1. SiriusXM Onyx Plus Case Replacement: adım 2, 3 resimden 2. SiriusXM Onyx Plus Case Replacement: adım 2, 3 resimden 3.
    • Starting with the bottom left corner, press down on the plastic opening tool to unhook the latches on the inside of the device.
    • You have to start with the bottom left and right corners, and then flip the device to over and do the top of the device.
  3. SiriusXM Onyx Plus Case Replacement: adım 3, 1 resimden 1.
    • Once unclipped, separate the back casing from the device.
Sonuç
Angel Rivera
532 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G2, Passmore Spring 2018 USF Tampa, Team S7-G2, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S7G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 305
