Ana içeriğe geç
SiriusXM Onyx Plus Motherboard Replacement
Neye ihtiyacın var
  1. SiriusXM Onyx Plus Motherboard Replacement, Case: adım 1, 1 resimden 1.
    • Wedge a plastic opening tool in between the case.
  2. SiriusXM Onyx Plus Motherboard Replacement: adım 2, 3 resimden 1. SiriusXM Onyx Plus Motherboard Replacement: adım 2, 3 resimden 2. SiriusXM Onyx Plus Motherboard Replacement: adım 2, 3 resimden 3.
    • Starting with the bottom left corner, press down on the plastic opening tool to unhook the latches on the inside of the device.
    • You have to start with the bottom left and right corners, and then flip the device to over and do the top of the device.
  3. SiriusXM Onyx Plus Motherboard Replacement: adım 3, 1 resimden 1.
    • Once unclipped, separate the back casing from the device.
  4. SiriusXM Onyx Plus Motherboard Replacement, Motherboard: adım 4, 2 resimden 1. SiriusXM Onyx Plus Motherboard Replacement, Motherboard: adım 4, 2 resimden 2.
    • Remove the three 5.4mm JIS #00 screws from the motherboard.
  5. SiriusXM Onyx Plus Motherboard Replacement: adım 5, 1 resimden 1.
    • Unlatch the two clips located at the top of the device that hold the motherboard in place.
  6. SiriusXM Onyx Plus Motherboard Replacement: adım 6, 1 resimden 1.
    • Lift the motherboard up from the bottom.
  7. SiriusXM Onyx Plus Motherboard Replacement: adım 7, 1 resimden 1.
    • Lift the screen up, so you can see where it is attached to the motherboard.
  8. SiriusXM Onyx Plus Motherboard Replacement: adım 8, 1 resimden 1.
    • Use a spudger to flip up the retaining flap on the display ribbon cable ZIF socket.
  9. SiriusXM Onyx Plus Motherboard Replacement: adım 9, 1 resimden 1.
    • Carefully pull the ribbon out from the ZIF connector.
Sonuç
Angel Rivera
532 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S7-G2, Passmore Spring 2018 USF Tampa, Team S7-G2, Passmore Spring 2018 üyesi
USFT-PASSMORE-S18S7G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 22
Her zaman: 1,787
