Ana içeriğe geç
Skateboard Hanger Replacement
Neye ihtiyacın var
  1. Skateboard Hanger  Replacement, Hanger: adım 1, 2 resimden 1. Skateboard Hanger  Replacement, Hanger: adım 1, 2 resimden 2.
    • Using the T-tool, unscrew the nut securing the wheel and remove it, setting it and the wheel aside.
  2. Skateboard Hanger  Replacement: adım 2, 3 resimden 1. Skateboard Hanger  Replacement: adım 2, 3 resimden 2. Skateboard Hanger  Replacement: adım 2, 3 resimden 3.
    • Using the T-Tool, unscrew the Kingpin nut, washer and top bushing so that the hanger itself can be taken off.
  3. Skateboard Hanger  Replacement: adım 3, 2 resimden 1. Skateboard Hanger  Replacement: adım 3, 2 resimden 2.
    • Pull straight up to remove the hanger. Remove the lower bushing and the lower cup washer just to check on the riser.
  4. Skateboard Hanger  Replacement: adım 4, 2 resimden 1. Skateboard Hanger  Replacement: adım 4, 2 resimden 2.
    • To reassemble, take the lower cup washer, then the lower bushing and put it on the kingpin. Next, set the replacement hanger on top of the lower bushing.
  5. Skateboard Hanger  Replacement: adım 5, 3 resimden 1. Skateboard Hanger  Replacement: adım 5, 3 resimden 2. Skateboard Hanger  Replacement: adım 5, 3 resimden 3.
    • After the hanger is added, put the the top bushing, the top cup washer and then the Kingpin nut back.
  6. Skateboard Hanger  Replacement: adım 6, 3 resimden 1. Skateboard Hanger  Replacement: adım 6, 3 resimden 2. Skateboard Hanger  Replacement: adım 6, 3 resimden 3.
    • After the kingpin nut is secured, take your T-Tool and add the wheels back onto and secure them in place.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 460
