Ana içeriğe geç
Skateboard Wheel Replacement
Neye ihtiyacın var
  1. Skateboard Wheel Replacement, The skate board fix up: adım 1, 1 resimden 1.
    • With a 13mm wrench, remove the axle nut located in the center of the wheel.
    • Set the axle nut aside, and remove the wheel.
    FixBot'a Sor
    Yorum Ekle
  2. Skateboard Wheel Replacement, Remove the Bearings: adım 2, 1 resimden 1.
    • Position the wheel at the end of the axle.
    • To remove the bearings, gently pry the wheel at a downward angle.
    • Perform this prying process on both sides of the wheel.
    • A bearing spacer should fall out once the bearings are removed.
    FixBot'a Sor
    Yorum Ekle
  3. Skateboard Wheel Replacement: adım 3, 1 resimden 1.
    • Position the new wheel on a flat surface.
    • Press the bearing into the hole of the new wheel.
    • Press firmly until the bearing snaps into place. The bearing's outside edges should be flush with the inside bottom edge of the wheel.
    FixBot'a Sor
    Yorum Ekle
  4. Skateboard Wheel Replacement: adım 4, 1 resimden 1.
    • Flip the wheel over.
    • Insert the bearing spacer into the back the wheel.
    FixBot'a Sor
    Yorum Ekle
  5. Skateboard Wheel Replacement: adım 5, 1 resimden 1.
    • Repeat the method from Step 3 to insert a bearing into the backside of the wheel.
    • With the bearings in place, the wheel can be placed on the axle.
    FixBot'a Sor
    Yorum Ekle
  6. Skateboard Wheel Replacement: adım 6, 1 resimden 1.
    • Slide one washer onto the axle.
    FixBot'a Sor
    Yorum Ekle
  7. Skateboard Wheel Replacement: adım 7, 1 resimden 1.
    • Slide the wheel onto the axle.
    • The axle should go through both bearings and the bearing spacer.
    FixBot'a Sor
    Yorum Ekle
  8. Skateboard Wheel Replacement: adım 8, 1 resimden 1.
    • Slide the second washer onto the axle on the outside of the wheel.
    FixBot'a Sor
    Yorum Ekle
  9. Skateboard Wheel Replacement: adım 9, 1 resimden 1.
    • Tighten the axle nut firmly.
    • Do not over tighten. The wheel should spin freely.
    • Repeat steps 1-9 for the remaining wheels.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Once your wheels are installed, you can ride your skateboard. If you feel your wheels hitting the bottom of your deck when you are turning, you may want to refer to the Wheel Bite Prevention guide.
9 farklı kişi bu kılavuzu tamamladı.
Jared Stine
800 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-32, Regan Fall 2012 Cal Poly, Team 6-32, Regan Fall 2012 üyesi
CPSU-REGAN-F12S6G32
5 Üyeler
6 adet Kılavuz yazıldı
3Kılavuz Yorumları
Very helpful - just got a skateboard for my son and used this guide to adjust two wheels.
emvxl - Yanıt Paylaş
thanks- i needed to upgrade my enjoi wheels to ricta clouds. thanks
Kenzie Peck - Yanıt Paylaş
Great and awesome post. It is very helpful. This blog shows the importance of blog commenting. Thanks https://skatingkits.com/best-skateboard-...
Kelly Brien - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 16
Son 30 gün: 70
Her zaman: 79,576
