Ana içeriğe geç
Skil 1743-AA Corded SDS+ Hammer Drill Disassembly
Neye ihtiyacın var
  1. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly, Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 1, 1 resimden 1.
    • The Skil 1743-AA Cordles SDS+ Hammer Drill is an affordable tool for serious hole drilling. Note that this one had its labels removed and the cord cut off for educational purposes.
  2. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 2, 3 resimden 1. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 2, 3 resimden 2. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 2, 3 resimden 3.
    • Make sure the drill is not plugged in. In our case, this was easy.
    • With a Phillips size 2 screwdriver, unscrew the four 40mm screws from the front body.
    • The front comes right off. Unfortunately this part is very rigidly put together, in fact so rigidly we were not able to disassemble it any further.
  3. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 3, 1 resimden 1.
    • Flip over the rear body, and unscrew the 9 20mm screws.
  4. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 4, 2 resimden 1. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 4, 2 resimden 2.
    • With a pry tool, separate the two halves. You might need to go all around before they come loose.
    • Take a moment to admire all that is inside.
  5. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 5, 3 resimden 1. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 5, 3 resimden 2. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 5, 3 resimden 3.
    • Unscrew the two 15mm screws that secure the cord.
    • The cord and its cradle look like one part, but actually they aren't.
  6. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 6, 2 resimden 1. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 6, 2 resimden 2.
    • Before we go any further, release the rotor from the motor assembly. Beautiful thing to behold, no?
    • You might need to lift the bearing from its position behind the motor in order to take the rotor out.
  7. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 7, 2 resimden 1. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 7, 2 resimden 2.
    • With pliers, cut the cable ties that secure the cable tree.
  8. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 8, 2 resimden 1. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 8, 2 resimden 2.
    • The complete innards should come out easily.
  9. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 9, 3 resimden 1. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 9, 3 resimden 2. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 9, 3 resimden 3.
    • We are now going to take out the power cable. Its leads are attached to the trigger box.
    • With a size 3 slotted screwdriver, unscrew the two 10mm brass screws to release the power cord.
  10. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 10, 3 resimden 1. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 10, 3 resimden 2. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 10, 3 resimden 3.
    • Pull apart the trigger and polarity switch boxes.
    • With your size 3 slotted screwdriver, or the pry, pry off the lid of the polarity switch. Using this switch the current to the motor is reversed to it turns the other way.
    • Interesting spring mechanism!
  11. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 11, 3 resimden 1. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 11, 3 resimden 2. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 11, 3 resimden 3.
    • Flip over the polarity swith box. The brushes that transfer power to the motor are attached inside here.
    • The wires are not soldered which allows you to replace the brushes. Don't lose the springs that hold 'em in place though!
  12. Skil 1743-AA Corded SDS+ Hammer Drill Disassembly: adım 12, 1 resimden 1.
    • You have completed the disassembly!
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 36
Her zaman: 1,047
