Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
Use the socket wrench to remove the 0.5" length screw from the bottom of the handle.
Remove the two 1" flathead screws located at the top and bottom of the motor housing.
After you have placed the motor housing back into the drill during reassembly, thread the wires down to the handle using tweezers.
Plug the forked wire into the socket at the back of the motor housing using tweezers.
