Ana içeriğe geç
Skil 88 Motor Replacement
Neye ihtiyacın var
  1. Skil 88 Motor Replacement, Disassembling Skil 88 Front Housing: adım 1, 1 resimden 1.
    • On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
    FixBot'a Sor
    Yorum Ekle
  2. Skil 88 Motor Replacement: adım 2, 2 resimden 1. Skil 88 Motor Replacement: adım 2, 2 resimden 2.
    • Pull the front housing apart from the rear.
    • The motor and gears might fall out when you are pulling it apart.
    FixBot'a Sor
    Yorum Ekle
  3. Skil 88 Motor Replacement, Motor: adım 3, 2 resimden 1. Skil 88 Motor Replacement, Motor: adım 3, 2 resimden 2.
    • Remove the gear that is threaded onto the divider.
    FixBot'a Sor
    Yorum Ekle
  4. Skil 88 Motor Replacement: adım 4, 2 resimden 1. Skil 88 Motor Replacement: adım 4, 2 resimden 2.
    • Remove the divider from the rear housing.
    • The motor may come out along with the divider.
    FixBot'a Sor
    Yorum Ekle
  5. Skil 88 Motor Replacement: adım 5, 2 resimden 1. Skil 88 Motor Replacement: adım 5, 2 resimden 2.
    • Pull out the motor.
    FixBot'a Sor
    Yorum Ekle
  6. Skil 88 Motor Replacement: adım 6, 3 resimden 1. Skil 88 Motor Replacement: adım 6, 3 resimden 2. Skil 88 Motor Replacement: adım 6, 3 resimden 3.
    Bu adımda kullanılan alet:
    • For reassembly, remove the orange cap on top using your flathead screwdriver. A bushing should come out with it.
    • Depress the bushing on bottom using the tweezers. To reach the bushing you will have to put the tweezers through the "Skil" lettering. Insert the motor as it is depressed.
    • Using the tweezers, place the other bushing back in through the hole in the top. Screw the orange cap back on.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To continue reassembly, simply follow the guide backwards starting at step 2.
Matt
365 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-17, Maness Fall 2010 Cal Poly, Team 5-17, Maness Fall 2010 üyesi
CPSU-MANESS-F10S5G17
3 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 10
Son 30 gün: 39
Her zaman: 1,079
