Ana içeriğe geç
Skil 88 Trigger Mechanism Replacement
Neye ihtiyacın var
  1. Skil 88 Trigger Mechanism Replacement, Trigger Housing: adım 1, 2 resimden 1. Skil 88 Trigger Mechanism Replacement, Trigger Housing: adım 1, 2 resimden 2.
    • Use the socket wrench to remove the 0.5" length screw from the bottom of the handle.
  2. Skil 88 Trigger Mechanism Replacement: adım 2, 3 resimden 1. Skil 88 Trigger Mechanism Replacement: adım 2, 3 resimden 2. Skil 88 Trigger Mechanism Replacement: adım 2, 3 resimden 3.
    • Separate the cord from the handle.
  3. Skil 88 Trigger Mechanism Replacement, Trigger Mechanism: adım 3, 1 resimden 1.
    • Make sure that the drill is completely unplugged.
    • Locate the two wires attached to the black trigger.
    • Pull the wires out of the trigger. It may take a bit of force.
  4. Skil 88 Trigger Mechanism Replacement: adım 4, 1 resimden 1.
    • Push the wires into the new trigger piece.
    • Make sure the wires go back into the correct holes.
Sonuç
Matt
365 İtibar
7 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 5-17, Maness Fall 2010 Cal Poly, Team 5-17, Maness Fall 2010 üyesi
CPSU-MANESS-F10S5G17
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 2,843
