Ana içeriğe geç
SkullCandy Hesh Auxiliary Cable Replacement
Neye ihtiyacın var
    1. SkullCandy Hesh Auxiliary Cable Replacement, Determine the damage: adım 1, 1 resimden 1.
      • Gently gripping the auxiliary cable of your headset, run your fingers down it's length, feeling for bumps or tears in the plastic sheathing. If there are multiple damaged areas, choose the one closest to the device.
      FixBot'a Sor
      Yorum Ekle
    2. SkullCandy Hesh Auxiliary Cable Replacement: adım 2, 1 resimden 1.
      • Using wire cutters, cut the auxiliary cable at the determined damaged area.
      • Next, cut your replacement cable to the same length of the removed portion of the damaged cable.
      FixBot'a Sor
      Yorum Ekle
    3. SkullCandy Hesh Auxiliary Cable Replacement: adım 3, 2 resimden 1. SkullCandy Hesh Auxiliary Cable Replacement: adım 3, 2 resimden 2.
      • Using the spudger tool, grip and remove approximately an inch of the plastic sheath from the device's working wire and from the new auxiliary cable.
      FixBot'a Sor
      Yorum Ekle
    4. SkullCandy Hesh Auxiliary Cable Replacement: adım 4, 1 resimden 1.
      • Use the spudger tool to remove the coating on the smaller colored wires inside the wire attached to the device and the new auxiliary cable.
      • Twist together the same colored wires from the device cable and the new cable.
      FixBot'a Sor
      Yorum Ekle
    5. SkullCandy Hesh Auxiliary Cable Replacement: adım 5, 1 resimden 1.
      • Wrap each of the individual colored wires with electrical tape to insulate them from the other wires.
      FixBot'a Sor
      Yorum Ekle
    6. SkullCandy Hesh Auxiliary Cable Replacement: adım 6, 1 resimden 1.
      • Secure all wires with a layer of electrical tape wrapped around the location of the splicing.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Test your device by plugging it into a compatible device using the auxiliary cable and playing a sound.
Sarah Burk
247 İtibar
3 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 16
Son 30 gün: 46
Her zaman: 1,477
