Ana içeriğe geç
SkullCandy Hesh Size Adjuster Replacement
Neye ihtiyacın var
    1. SkullCandy Hesh Size Adjuster Replacement, Determine the damage: adım 1, 2 resimden 1. SkullCandy Hesh Size Adjuster Replacement, Determine the damage: adım 1, 2 resimden 2.
      • Locate the break in the device.
      FixBot'a Sor
      Yorum Ekle
    2. SkullCandy Hesh Size Adjuster Replacement: adım 2, 1 resimden 1.
      • Use a Phillips #0 screwdriver to remove the two 9 mm screws from the bottom inner casing beneath the break.
      FixBot'a Sor
      Yorum Ekle
    3. SkullCandy Hesh Size Adjuster Replacement: adım 3, 1 resimden 1.
      • Remove the bottom inner casing to reveal the wire compartment and the port where the slider inserts.
      FixBot'a Sor
      Yorum Ekle
    4. SkullCandy Hesh Size Adjuster Replacement: adım 4, 2 resimden 1. SkullCandy Hesh Size Adjuster Replacement: adım 4, 2 resimden 2.
      • Cover the detached slider port in a generous layer of Plasti Dip, which works like glue. Also coat any exposed wire to seal the circuit.
      FixBot'a Sor
      Yorum Ekle
    5. SkullCandy Hesh Size Adjuster Replacement: adım 5, 1 resimden 1.
      • Realign the broken size adjuster into the port with the Plasti Dip so that it can be secured to the ear piece.
      FixBot'a Sor
      Yorum Ekle
    6. SkullCandy Hesh Size Adjuster Replacement: adım 6, 1 resimden 1.
      • Clamp the pieces in place by hand or with a binder clip until the Plasti Dip dries. Feel free to use a hair dryer on a low setting to speed up the process.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, reattach the bottom inner casing with the Phillips #0 screwdriver and two removed screws.
Sarah Burk
247 İtibar
3 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 1,279
