Ana içeriğe geç
SkullCandy Hesh Size Adjuster Replacement
Neye ihtiyacın var
  1. SkullCandy Hesh Size Adjuster Replacement, Determine the damage: adım 1, 2 resimden 1. SkullCandy Hesh Size Adjuster Replacement, Determine the damage: adım 1, 2 resimden 2.
    • Locate the break in the device.
  2. SkullCandy Hesh Size Adjuster Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove the two 9 mm screws from the bottom inner casing beneath the break.
  3. SkullCandy Hesh Size Adjuster Replacement: adım 3, 1 resimden 1.
    • Remove the bottom inner casing to reveal the wire compartment and the port where the slider inserts.
  4. SkullCandy Hesh Size Adjuster Replacement: adım 4, 2 resimden 1. SkullCandy Hesh Size Adjuster Replacement: adım 4, 2 resimden 2.
    • Cover the detached slider port in a generous layer of Plasti Dip, which works like glue. Also coat any exposed wire to seal the circuit.
  5. SkullCandy Hesh Size Adjuster Replacement: adım 5, 1 resimden 1.
    • Realign the broken size adjuster into the port with the Plasti Dip so that it can be secured to the ear piece.
  6. SkullCandy Hesh Size Adjuster Replacement: adım 6, 1 resimden 1.
    • Clamp the pieces in place by hand or with a binder clip until the Plasti Dip dries. Feel free to use a hair dryer on a low setting to speed up the process.
Sonuç
To reassemble your device, reattach the bottom inner casing with the Phillips #0 screwdriver and two removed screws.
Sarah Burk
247 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 15
Her zaman: 868
