Ana içeriğe geç
Skullcandy Air Raid Back Panel Replacement
Salt Önkoşul
Bu kılavuz yalnızca diğer kılavuzlar için bir ön koşul olarak kullanılmak üzere tasarlanmıştır. Tek başına eksiktir.
Neye ihtiyacın var
  1. Skullcandy Air Raid Back Panel Replacement, Rubber Cover: adım 1, 1 resimden 1.
    • Starting with the corners, gently pull the rubber cover off of the device.
  2. Skullcandy Air Raid Back Panel Replacement, Handle: adım 2, 1 resimden 1.
    • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
    • Remove the handle from the device.
  3. Skullcandy Air Raid Back Panel Replacement, Front Plate: adım 3, 1 resimden 1.
    • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
    • One 5mm Phillips screw.
    • One 8mm Phillips screw.
  4. Skullcandy Air Raid Back Panel Replacement: adım 4, 1 resimden 1.
    • Gently pull the sides of the front plate outwards from the device.
    • Pull up on the front plate to remove it from the device.
  5. Skullcandy Air Raid Back Panel Replacement, Speakers: adım 5, 1 resimden 1.
    • Using a #000 Philips Screwdriver, unscrew the four 8 mm Philips screws from each corner of both speakers (eight 8 mm Philips screws total).
  6. Skullcandy Air Raid Back Panel Replacement: adım 6, 1 resimden 1.
    • Using the plastic opening tool, pry around edges of the speaker to loosen glue contact with front plate.
    • If you are unable to loosen glue contact using the plastic opening tool, use a heat gun to assist in removal.
  7. Skullcandy Air Raid Back Panel Replacement: adım 7, 1 resimden 1.
    • Lift the speaker out of the device.
    • Be aware of the connection with the ribbon cable.
    • For reassembly, ensure proper orientation of the cable plug.
  8. Skullcandy Air Raid Back Panel Replacement: adım 8, 1 resimden 1.
    • Firmly pull on the end of ribbon cable to disconnect the speaker from the motherboard.
  9. Skullcandy Air Raid Back Panel Replacement, Control Buttons: adım 9, 1 resimden 1.
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, above and below volume buttons.
  10. Skullcandy Air Raid Back Panel Replacement: adım 10, 1 resimden 1.
    • Lift the button panel.
  11. Skullcandy Air Raid Back Panel Replacement, Button Motherboard: adım 11, 1 resimden 1.
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
  12. Skullcandy Air Raid Back Panel Replacement: adım 12, 1 resimden 1.
    • Using a plastic opening tool, pry the button motherboard to detach it from the device.
    • The button motherboard is connected to a ribbon cable inside the device.
  13. Skullcandy Air Raid Back Panel Replacement, Ribbon Cable: adım 13, 1 resimden 1.
    • Pull the black ribbon cord attachment away from the motherboard.
    • Pull on the cable until it releases from the back of the motherboard.
    • The black attachment is part of the connector, not the blue ribbon cable, so it will not disconnect from the motherboard.
  14. Skullcandy Air Raid Back Panel Replacement, Back panel: adım 14, 2 resimden 1. Skullcandy Air Raid Back Panel Replacement, Back panel: adım 14, 2 resimden 2.
    • Using a Phillips #00 Precision Screwdriver, unscrew two 8 mm screws.
    • Lift off the back panel.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 79
