Giriş
If your Skullcandy Air Raid will not maintain power even after charging, it may be time to replace the battery.
Neye ihtiyacın var
Starting with the corners, gently pull the rubber cover off of the device.
Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
Remove the handle from the device.
Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
One 5mm Phillips screw.
One 8mm Phillips screw.
Using a #000 Philips Screwdriver, unscrew the four 8 mm Philips screws from each corner of both speakers (eight 8 mm Philips screws total).
Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, above and below volume buttons.
Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
Pull the black ribbon cord attachment away from the motherboard.
Pull on the cable until it releases from the back of the motherboard.
Using a Phillips #00 Precision Screwdriver, unscrew two 8 mm screws.
Lift off the back panel.
Pull on the ribbon cable that connects the battery to the motherboard until the connector releases.
6 farklı kişi bu kılavuzu tamamladı.
6 Yorum
Hi, my name is Alex, and i have the same problem. The battery does not work anymore, but i don't know where can i find a replacement, and what is the its name. Or mabe something similar? I live in Romania so i need mabe an international online store to buy it. Thank you! My email is stanciualex_e@ yahoo.com
What is the type of battery?
I have the same issue. I want to acquire a replacement.
It is a rechargeable battery Model AEC553450-2P / 2000mA 3.7V 7.4Wh.
It there anybody out there who could help us I will appreciate it very much
I also need a battery, have you found one?
