Ana içeriğe geç
Skullcandy Air Raid Buttons Replacement
Neye ihtiyacın var
  1. Skullcandy Air Raid Buttons Replacement, Rubber Cover: adım 1, 1 resimden 1.
    • Starting with the corners, gently pull the rubber cover off of the device.
    FixBot'a Sor
    Yorum Ekle
  2. Skullcandy Air Raid Buttons Replacement, Handle: adım 2, 1 resimden 1.
    • Using the T-6 hexagonal screwdriver, unscrew the four 10mm #6 hex screws on the right side of the device.
    • Remove the handle from the device.
    FixBot'a Sor
    Yorum Ekle
  3. Skullcandy Air Raid Buttons Replacement, Front Plate: adım 3, 1 resimden 1.
    • Unscrew the two screws on the left side of the device using the phillips #00 screwdriver.
    • One 5mm Phillips screw.
    • One 8mm Phillips screw.
    FixBot'a Sor
    Yorum Ekle
  4. Skullcandy Air Raid Buttons Replacement: adım 4, 1 resimden 1.
    • Gently pull the sides of the front plate outwards from the device.
    • Pull up on the front plate to remove it from the device.
    FixBot'a Sor
    Yorum Ekle
  5. Skullcandy Air Raid Buttons Replacement, Control Buttons: adım 5, 2 resimden 1. Skullcandy Air Raid Buttons Replacement, Control Buttons: adım 5, 2 resimden 2.
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the middle of the panel, specifically above and below the volume buttons.
    • Lift the button panel.
    FixBot'a Sor
    Yorum Ekle
  6. Skullcandy Air Raid Buttons Replacement, Button Motherboard: adım 6, 1 resimden 1.
    • Using a Phillips #00 Precision Screwdriver, unscrew two 6 mm screws from the button motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. Skullcandy Air Raid Buttons Replacement: adım 7, 1 resimden 1.
    • Using a plastic opening tool, pry up on the button motherboard to detach it from the device.
    • The button motherboard is connected to a ribbon cable inside the device.
    FixBot'a Sor
    Yorum Ekle
  8. Skullcandy Air Raid Buttons Replacement, Ribbon Cable: adım 8, 1 resimden 1.
    • First, pull on the black attachment to disconnect it from the metal piece.
    • Release the cable from the back of the motherboard.
    • The black attachment is a part of the connector, not the blue ribbon cable. It will not disconnect from the motherboard.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 28
Her zaman: 1,626
