Ana içeriğe geç
Giriş
You will use this guide to replace the folding hinge in a Skullcandy Crusher Wireless headphones. Replacement folding hinges can be bought online or taken from another Skullcandy Crusher Wireless headphone.
Parçalar
Hiçbir parça belirtilmedi.
  1. Extend and fold the hinge of the headphones you are trying to replace. Extend and fold the hinge of the headphones you are trying to replace. Extend and fold the hinge of the headphones you are trying to replace.
    • Extend and fold the hinge of the headphones you are trying to replace.
  2. Remove two 14 mm Torx T6  screws on the underside of the headband. Remove two 14 mm Torx T6  screws on the underside of the headband. Remove two 14 mm Torx T6  screws on the underside of the headband.
    • Remove two 14 mm Torx T6 screws on the underside of the headband.
  3. Pry the speaker away from the headband with a slight force. Pry the speaker away from the headband with a slight force. Pry the speaker away from the headband with a slight force.
    • Pry the speaker away from the headband with a slight force.
  4. Remove two 5 mm Phillips #1 screws on the underside of the headband. Remove two 5 mm Phillips #1 screws on the underside of the headband. Remove two 5 mm Phillips #1 screws on the underside of the headband.
    • Remove two 5 mm Phillips #1 screws on the underside of the headband.
  5. Remove the top plastic part of the hinge. Remove the top plastic part of the hinge.
    • Remove the top plastic part of the hinge.
Sonuç
Valerii
690 İtibar
6 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 1-33, Gurgel Spring 2022 UMass Dartmouth, Team 1-33, Gurgel Spring 2022 üyesi
UMASSD-GURGEL-S22S1G33
1 Üye
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 10
Son 7 gün: 41
Son 30 gün: 76
Her zaman: 89
