Ana içeriğe geç
Determining Wire Connectivity for Skullcandy Lowrider
Neye ihtiyacın var
  1. Determining Wire Connectivity for Skullcandy Lowrider, Checking to See if the Wire is Still Connected to the Ear-Cup: adım 1, 2 resimden 1. Determining Wire Connectivity for Skullcandy Lowrider, Checking to See if the Wire is Still Connected to the Ear-Cup: adım 1, 2 resimden 2.
    • Pull the edge of the pad where it meets the plastic of the ear-cup to separate the padding from the ear pad.
  2. Determining Wire Connectivity for Skullcandy Lowrider: adım 2, 2 resimden 1. Determining Wire Connectivity for Skullcandy Lowrider: adım 2, 2 resimden 2.
    • Use the small Phillips screwdriver to remove three 8mm screws on the surface of the earphones.
  3. Determining Wire Connectivity for Skullcandy Lowrider: adım 3, 1 resimden 1.
    • Now that the screws have been removed, use your hands to separate the plate from the rest of headphone.
    • Here, you will be able to check the connectivity of your auxiliary cord to its port in an appropriate ear-cup.
  4. Determining Wire Connectivity for Skullcandy Lowrider: adım 4, 1 resimden 1.
    • Now that you have removed the plate you can check the wiring connectivity. If the wire is not connected to any sources inside the ear-cup, as shown in the image to the right, then this is the reason that your headphone(s) are not working.
    • Now that you have verified your problem, refer to the guide Skullcandy Lowrider Wiring Repair to fix the loose wiring.
Sonuç
Ryley
273 İtibar
3 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 977
