Ana içeriğe geç
Skullcandy Mix Master DJ Mylar Driver Replacement
Neye ihtiyacın var
  1. Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: adım 1, 3 resimden 1. Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: adım 1, 3 resimden 2. Skullcandy Mix Master DJ Mylar Driver Replacement, Mylar Driver: adım 1, 3 resimden 3.
    • With the plastic opening tool, separate the padded ear cup from the main speaker component.
    • Make sure to fold the ear cup inward to avoid getting in the way of the opposite side.
  2. Skullcandy Mix Master DJ Mylar Driver Replacement: adım 2, 1 resimden 1.
    • Using your screw driver, remove the six Philips 2mm screws located on the chrome ring.
  3. Skullcandy Mix Master DJ Mylar Driver Replacement: adım 3, 2 resimden 1. Skullcandy Mix Master DJ Mylar Driver Replacement: adım 3, 2 resimden 2.
    • Using your screw driver, remove the four 3mm Phillips screws located on the grey speaker.
    • Remove the driver from the gray speaker assembly.
    • Carefully remove the driver assembly since there are wires connected to the headphone jack, headband, and mute button.
  4. Skullcandy Mix Master DJ Mylar Driver Replacement: adım 4, 2 resimden 1. Skullcandy Mix Master DJ Mylar Driver Replacement: adım 4, 2 resimden 2.
    • Using your screw driver, remove the two 2mm Phillips screws located on the circuit panel of the audio jack.
    • Carefully separate the jack from the ear cup casing.
    • If you are working on the right ear cup, the mute button circuit board may be difficult to remove.
  5. Skullcandy Mix Master DJ Mylar Driver Replacement: adım 5, 2 resimden 1. Skullcandy Mix Master DJ Mylar Driver Replacement: adım 5, 2 resimden 2.
    • The Mylar driver is connected to several small circuit boards by soldered wires. It can only be removed by cutting the connecting wires.
    • Do not pull the driver away too fast since there are wires connecting the driver to the ear cup.
    • Soldering Guide: https://www.youtube.com/watch?v=urGB_IUX...
Sonuç
Bir başkası bu kılavuzu tamamladı.
Sean Herlihy
117 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-3, Shastany Spring 2015 UMass Dartmouth, Team 1-3, Shastany Spring 2015 üyesi
UMASSD-SHASTANY-S15S1G3
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 1,527
