Ana içeriğe geç
Sky 6.0Q Battery Replacement
Neye ihtiyacın var
  1. Sky 6.0Q Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Battery Replacement: adım 2, 1 resimden 1.
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Battery Replacement: adım 3, 2 resimden 1. Sky 6.0Q Battery Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Battery Replacement: adım 4, 1 resimden 1.
    • Disconnect the gold cord extending from the battery to the top electronic board.
    • Use the nylon spudger to help pry up the battery attachment.
    • To reattach the gold cord and battery attachment connection, gently press piece back in place.
  5. Sky 6.0Q Battery Replacement: adım 5, 1 resimden 1.
    • Use the nylon spudger to get underneath the battery and separate it from the phone back.
    • There is a white, milky adhesive so be careful to not rip or puncture the battery during removal.
  6. Sky 6.0Q Battery Replacement: adım 6, 1 resimden 1.
    • Once separated, remove battery and replace with a new battery.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Monica Difato
429 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G3, Hovde Fall 2018 IUPUI, Team S1-G3, Hovde Fall 2018 üyesi
IUPUI-HOVDE-F18S1G3
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 47
Her zaman: 2,317
