Ana içeriğe geç
Sky 6.0Q Front Camera Replacement
Neye ihtiyacın var
  1. Sky 6.0Q Front Camera Replacement, Front Camera: adım 1, 1 resimden 1.
    • Use the #00 Phillips screwdriver to remove the two 3 mm screws at the bottom of the backplate.
    • Pry off the back plate with the spudger.
  2. Sky 6.0Q Front Camera Replacement: adım 2, 1 resimden 1.
    • After removing back panel, remove all ten 3mm screws with the #00 Phillips screwdriver from the black plastic casing so it can be removed.
  3. Sky 6.0Q Front Camera Replacement: adım 3, 2 resimden 1. Sky 6.0Q Front Camera Replacement: adım 3, 2 resimden 2.
    • Use the plastic opening tool to help pry up the plastic backing.
    • Once loose, remove the plastic backing to expose underlying electronic components.
  4. Sky 6.0Q Front Camera Replacement: adım 4, 2 resimden 1. Sky 6.0Q Front Camera Replacement: adım 4, 2 resimden 2.
    • Disconnect the electronic adapter connecting the camera to the top mother board.
    • Once disconnected, remove the camera and replace with new camera. If necessary, use the spudger to help remove the camera.
    • To reattach front camera electrical connection, gently press piece back in place.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Robert Berardi
247 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G3, Hovde Fall 2018 IUPUI, Team S1-G3, Hovde Fall 2018 üyesi
IUPUI-HOVDE-F18S1G3
3 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 11
Son 30 gün: 19
Her zaman: 256
