Ana içeriğe geç
Sky Thunder HD 8500WH Lower and Upper Body Replacement
Neye ihtiyacın var
  1. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Rotor Blade: adım 1, 3 resimden 1. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Rotor Blade: adım 1, 3 resimden 2. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Rotor Blade: adım 1, 3 resimden 3.
    • Place the drone with the top side facing up.
    • Remove the blade cover.
    • Remove the rotor blade.
  2. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lockstitch: adım 2, 2 resimden 1. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lockstitch: adım 2, 2 resimden 2.
    • Unscrew the 1cm screw holding in the blade lockstitch with the Phillips 0 Screwdriver.
    • Remove the blade lockstitch.
  3. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lower and Upper Body: adım 3, 3 resimden 1. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lower and Upper Body: adım 3, 3 resimden 2. Sky Thunder HD 8500WH Lower and Upper Body Replacement, Lower and Upper Body: adım 3, 3 resimden 3.
    • Lay down the drone so the battery side is facing up.
    • Unscrew all 5 .8cm screws on each arm of the drone with the Phillips 0 Screwdriver.
    • Repeat previous bullet for each arm (20 screws in total).
  4. Sky Thunder HD 8500WH Lower and Upper Body Replacement: adım 4, 2 resimden 1. Sky Thunder HD 8500WH Lower and Upper Body Replacement: adım 4, 2 resimden 2.
    • Using a bit of force, gently pull apart the lower and upper bodies.
    • Keep going until both parts are completely separated.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 126
