Ana içeriğe geç
Sky Thunder HD 8500WH Motor Replacement
Neye ihtiyacın var
  1. Sky Thunder HD 8500WH Motor Replacement, Rotor Blade: adım 1, 3 resimden 1. Sky Thunder HD 8500WH Motor Replacement, Rotor Blade: adım 1, 3 resimden 2. Sky Thunder HD 8500WH Motor Replacement, Rotor Blade: adım 1, 3 resimden 3.
    • Place the drone with the top side facing up.
    • Remove the blade cover.
    • Remove the rotor blade.
  2. Sky Thunder HD 8500WH Motor Replacement, Lockstitch: adım 2, 2 resimden 1. Sky Thunder HD 8500WH Motor Replacement, Lockstitch: adım 2, 2 resimden 2.
    • Unscrew the 1cm screw holding in the blade lockstitch with the Phillips 0 Screwdriver.
    • Remove the blade lockstitch.
  3. Sky Thunder HD 8500WH Motor Replacement, Lower and Upper Body: adım 3, 3 resimden 1. Sky Thunder HD 8500WH Motor Replacement, Lower and Upper Body: adım 3, 3 resimden 2. Sky Thunder HD 8500WH Motor Replacement, Lower and Upper Body: adım 3, 3 resimden 3.
    • Lay down the drone so the battery side is facing up.
    • Unscrew all 5 .8cm screws on each arm of the drone with the Phillips 0 Screwdriver.
    • Repeat previous bullet for each arm (20 screws in total).
  4. Sky Thunder HD 8500WH Motor Replacement: adım 4, 2 resimden 1. Sky Thunder HD 8500WH Motor Replacement: adım 4, 2 resimden 2.
    • Using a bit of force, gently pull apart the lower and upper bodies.
    • Keep going until both parts are completely separated.
  5. Sky Thunder HD 8500WH Motor Replacement, Gear: adım 5, 2 resimden 1. Sky Thunder HD 8500WH Motor Replacement, Gear: adım 5, 2 resimden 2.
    • Find the gear mechanism at the end of one of the drone arms.
    • Unscrew the two front .8cm screws with the Phillips 0 Screwdriver.
  6. Sky Thunder HD 8500WH Motor Replacement: adım 6, 2 resimden 1. Sky Thunder HD 8500WH Motor Replacement: adım 6, 2 resimden 2.
    • Remove the white spacer.
    • Remove the red spacer.
  7. Sky Thunder HD 8500WH Motor Replacement: adım 7, 1 resimden 1.
    • Pull the gear out from the bottom of the holding mechanism.
  8. Sky Thunder HD 8500WH Motor Replacement, Motor: adım 8, 2 resimden 1. Sky Thunder HD 8500WH Motor Replacement, Motor: adım 8, 2 resimden 2.
    • Unscrew the two .8cm screws on the bottom of the holding mechanism with the Phillips 0 Screwdriver.
    • Remove the motor from the holding mechanism.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 4
Son 30 gün: 7
Her zaman: 165
