Giriş
This guide will show how to take the device apart and how to identify components that need to be removed to replace the screen.
Neye ihtiyacın var
Make sure the device is powered off
Rotate the device so the ports and screws face you
Follow the Case Replacement to separate the tablet from its backing
Using a small Phillips screw driver, unscrew all screws connecting circuit board to device
Remove all tape connecting battery and circuit board to front case
Detach all connector strips from the circuit board
To reassemble your device with a new screen, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
