Ana içeriğe geç
Skytex SP728 Screen Replacement
Neye ihtiyacın var
  1. Skytex SP728 Screen Replacement, Case: adım 1, 1 resimden 1.
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Screen Replacement: adım 2, 1 resimden 1.
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Screen Replacement: adım 3, 1 resimden 1.
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Screen Replacement: adım 4, 1 resimden 1.
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Screen Replacement, Screen: adım 5, 3 resimden 1. Skytex SP728 Screen Replacement, Screen: adım 5, 3 resimden 2. Skytex SP728 Screen Replacement, Screen: adım 5, 3 resimden 3.
    • Follow the Case Replacement to separate the tablet from its backing
    • Using a small Phillips screw driver, unscrew all screws connecting circuit board to device
    • Remove all tape connecting battery and circuit board to front case
    • Detach all connector strips from the circuit board
  6. Skytex SP728 Screen Replacement: adım 6, 2 resimden 1. Skytex SP728 Screen Replacement: adım 6, 2 resimden 2.
    • Using the plastic opening tool, begin separating the front screen from the display
  7. Skytex SP728 Screen Replacement: adım 7, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Once screen has been separated, use tweezers to remove front camera
Sonuç
To reassemble your device with a new screen, follow these instructions in reverse order.
2 farklı kişi bu kılavuzu tamamladı.
Michelle Strickland
304 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-1, Brown Winter 2015 USF Tampa, Team 5-1, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G1
4 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 7
Her zaman: 305
