Ana içeriğe geç
Skytex SP728 Speakers Replacement
Neye ihtiyacın var
  1. Skytex SP728 Speakers Replacement, Case: adım 1, 1 resimden 1.
    • Make sure the device is powered off
    • Rotate the device so the ports and screws face you
  2. Skytex SP728 Speakers Replacement: adım 2, 1 resimden 1.
    • Using a small phillips screwdriver, unscrew both end screws
  3. Skytex SP728 Speakers Replacement: adım 3, 1 resimden 1.
    • Using a plastic opening tool, work your way around the edge of the device, separating the case from the rest of the device
  4. Skytex SP728 Speakers Replacement: adım 4, 1 resimden 1.
    • Once the case has been loosened, pry the backing off gently with your hands.
    • Make sure to remove the case gently as extra force can break the clasps or the case itself.
  5. Skytex SP728 Speakers Replacement, Speakers: adım 5, 1 resimden 1.
    • Identify the connection location of the wires from the speakers.
  6. Skytex SP728 Speakers Replacement: adım 6, 1 resimden 1.
    • Use a soldering iron to remove the speaker wires from the circuit board
  7. Skytex SP728 Speakers Replacement: adım 7, 1 resimden 1.
    • Solder the new speakers to the correct location, making sure the red wire goes to the + and the black wire goes to the -.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Chris Nelson
213 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 5-1, Brown Winter 2015 USF Tampa, Team 5-1, Brown Winter 2015 üyesi
USFT-BROWN-W15S5G1
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 97
