Giriş
It happens relatively often that the slider of the toaster no longer stays down, but the heaters still work. On most toasters the slider is held by an electromagnet at the bottom, here you will often find the malfunction: either the coil is defective or the magnet is contaminated with bread crumbs and can therefore no longer hold. This issue can be easily eliminated and the repair is about the same for many toasters.
The repair is shown on an old Tefal model 539627.
Neye ihtiyacın var
Pull off the button on the slider, you need a lot of strength to do this.
Also pull off the knob on the controller, a lever tool was used here.
Place the toaster face down on the work surface.
Pull out the crumb drawer.
Three of the screws are in the front half.
Two of the screws are in the other half under the crumb drawer.
Unscrew and remove all screws.
The upper part is screwed to the lower part. Here there are five Phillips screws that are in deep holes. Three of the screws are in the front half. Two of the screws are in the other half under the crumb drawer. Unscrew and remove all screws.
Insert a plastic tool into the seam between the upper and lower part and enlarge the gap all around.
Pull the top off the bottom, paying attention to the axes of the controller and the slider.
Lift the top off and put it aside.
Insert a plastic tool into the seam between the upper and lower part and enlarge the gap all around. Pull the top off the bottom, paying attention to the axes of the controller and the slider. This may require some strength. Lift the top off and put it aside
Here are the main internal parts:
The contacts for the heating wires. They are switched when the slider moves down
The timer. The longer the time, the darker the toast.
The holding magnet, it's here where you have to look for the solution.
Here are the main internal parts: The contacts for the heating wires. They are switched when the slider moves down. The timing. The longer the time, the darker the toast becomes. The holding magnet. He holds the slider down. Here you have to look for the error
Thoroughly clean the space between the magnet and the iron holder. Use a cotton swab with alcohol.
There is an iron tilting device on the magnet, here embedded in a molded plastic part. When the magnet pulls in, it holds the hook on the slide. Thoroughly clean the space between the magnet and the iron holder. Use a cotton swab with alcohol.
Insert the power plug and test whether your repair was successful.
Pull the power plug again and clean the toaster thoroughly before assembling
Caution mains voltage: do not touch conductive parts! Insert the power plug and test whether your repair was successful. Pull the power plug again and clean the toaster thoroughly before assembling
To reassemble your toaster, follow these instructions in reverse order.
9 farklı kişi bu kılavuzu tamamladı.
Bu çevirmenlere özel teşekkürler:
100%
Bu çevirmenler dünyayı onarmamıza yardım ediyor! Katkıda bulunmak ister misiniz?
Çeviriye Başlayın ›
7 Yorum
Hey super, das klappte!!
Mein Toaster sieht leider anders innen.. schade, das hat nicht geklappt.
Hallo Elke,
es gibt neben den Toastern mit dem Magneten noch eine andere, weit verbreitete Toaster-Bauart, bei dem ein kleiner Haken aus Kunststoff oder Metall den Auswurf solange unten hält, bis ein Bimetall sich entspechend erwärmt oder eine Zeitschaltuhr auslöst. Häufig greifen diese kleinen Haken nicht mehr, und der Auswurf rutscht immer nach oben. Hier hilft in der Regel eine kleine Dreikantfeile oder die Rekonstruktion des Hakens.
Bei einigen Fällen ist aber auch der “Zeitgeber” defekt.
Danke!!! jetzt macht er wieder was er soll...hätte schon fast einen neuen bestellt. (Elta)
Grüße aus Österreich
Hat geklappt. KRUPS macht es einem aber schwerer. Eine der Schrauben ist nicht Kreuzschlitz, sondern TX10 mit Stirnloch (ein Schelm, wer ....). Das muss man bei einem schwarzen Gehäuse erstmal erkennen. Bei mir Schwachstelle dann aber nicht der Magnet selbst, sondern die Kontaktkorrosion an den Kupferlaschen, die beim Herunterdrücken des Hebels den Stromkreis schließen (vgl oben Bild bei Schritt 8, da sieht man sie rechts) oder eben auch nicht mehr. Da hilft dann Kontaktspray eher als Alkohol.
The repair is done on an old Tefal model 539627, but is the same for many toasters. Unplug the power cord before repairs
Matthew Newton - Yanıt
