Ana içeriğe geç
Slingbox SOLO Motherboard Replacement
Neye ihtiyacın var
  1. Slingbox SOLO Motherboard Replacement, Motherboard: adım 1, 1 resimden 1.
    • Use the plastic opening tool to remove the four rubber pads from the bottom of the device.
  2. Slingbox SOLO Motherboard Replacement: adım 2, 3 resimden 1. Slingbox SOLO Motherboard Replacement: adım 2, 3 resimden 2. Slingbox SOLO Motherboard Replacement: adım 2, 3 resimden 3.
    • The Slingbox has four black 5mm screws, one on each corner of the case.
    • Remove the four black 5mm screws using the PH1 screwdriver.
    • Gently pull and separate the two case covers.
  3. Slingbox SOLO Motherboard Replacement: adım 3, 3 resimden 1. Slingbox SOLO Motherboard Replacement: adım 3, 3 resimden 2. Slingbox SOLO Motherboard Replacement: adım 3, 3 resimden 3.
    • The motherboard has five silver 5.5mm screws connecting it to the base of the Slingbox.
    • Remove the five silver screws on the motherboard using the PH1 screwdriver.
    • Gently slide and separate the motherboard from the base.
Sonuç
Nitin Muralidhar
222 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team 2-2, Harley SU 2016 IUPUI, Team 2-2, Harley SU 2016 üyesi
IUPUI-HARLEY-SU16S2G2
5 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 584
