Ana içeriğe geç
Small Engine Recoil Starter Replacement
Neye ihtiyacın var
  1. Small Engine Recoil Starter Replacement, Recoil Starter: adım 1, 1 resimden 1.
    • To begin the repair remove the protective casing. (This removal may vary with different lawnmowers.)
  2. Small Engine Recoil Starter Replacement: adım 2, 1 resimden 1.
    • Locate the recoil housing cap.
  3. Small Engine Recoil Starter Replacement: adım 3, 1 resimden 1.
    • Carefully remove the housing cap. (Removal may vary)
  4. Small Engine Recoil Starter Replacement: adım 4, 1 resimden 1.
    • After removing the recoil, unscrew the cap that holds the pulley to the recoil starter housing.
  5. Small Engine Recoil Starter Replacement: adım 5, 1 resimden 1.
    • Untie the knot in the rope and slide it out of the housing.
  6. Small Engine Recoil Starter Replacement: adım 6, 1 resimden 1.
    • With this particular model there is a middle lock piece. Use a socket wrench to unscrew and release the coil.
  7. Small Engine Recoil Starter Replacement: adım 7, 1 resimden 1.
    • Once unscrewed, remove the metal piece which releases the tension on the coil.
  8. Small Engine Recoil Starter Replacement: adım 8, 1 resimden 1.
    • At this point add the new coil to the housing base. Snap the coil into position where the old on was.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 8
Son 30 gün: 25
Her zaman: 3,006
