Ana içeriğe geç
Giriş
Before opening the LCR-Reader, place a small bit of tape over the button on the top housing. This will keep the button from falling loose and being lost.
  1. Start by removing the 4 screws in the back of the device using a size 00 Philips screw driver. Start by removing the 4 screws in the back of the device using a size 00 Philips screw driver.
    • Start by removing the 4 screws in the back of the device using a size 00 Philips screw driver.
  2. Gently open the zif connector that holds the screen. Insert the replacement screen, and close the zif
    • Gently open the zif connector that holds the screen.
    • Insert the replacement screen, and close the zif
  3. When closing the housing, make sure the screen fits into the rectangle on the top.
    • When closing the housing, make sure the screen fits into the rectangle on the top.
    • If the screen is not in this rectangle, it may become damaged when the screws are tightened
    • Hold the screen in place from below; line up the button's edge of the top housing to line up with the bottom housing. Slide your finger out as you bring the top and bottom housings to meet.
    • Replace the 4 Philips screws in the back.
Bitiş Çizgisi
brittany
150 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 4
Her zaman: 271
