Ana içeriğe geç
Smartab STJR700 Charging Port Replacement
Neye ihtiyacın var
  1. Smartab STJR700 Charging Port Replacement, Charging Port: adım 1, 1 resimden 1.
    • Power off the device by holding down the lock button. Remove the case from the tablet and place it face down.
  2. Smartab STJR700 Charging Port Replacement: adım 2, 1 resimden 1.
    • Unscrew all four corner screws using the PH000 screwdriver head found in the iFixit kit.
  3. Smartab STJR700 Charging Port Replacement: adım 3, 1 resimden 1.
    • CAUTION: Avoid touching the display.
    • Pry open the tablet using a metal spudger. Set aside the back panel.
  4. Smartab STJR700 Charging Port Replacement: adım 4, 1 resimden 1.
    • Locate the charging port.
  5. Smartab STJR700 Charging Port Replacement: adım 5, 2 resimden 1. Smartab STJR700 Charging Port Replacement: adım 5, 2 resimden 2.
    • Unscrew all the labeled screws using the PH000 screwdriver head.
  6. Smartab STJR700 Charging Port Replacement: adım 6, 1 resimden 1.
    • Remove all pieces of tape using the tweezers provided in the iFixit kit.
    • Remove the two ribbon cables affixed to the camera.
  7. Smartab STJR700 Charging Port Replacement: adım 7, 1 resimden 1.
    • Remove the motherboard component from the screen and display.
    • Because the charging port is soldered onto the motherboard, the motherboard must be replaced by one specifically made for the Smartab STJR700.
Sonuç
Thi Le
101 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G4, Botvin Spring 2017 UMass Dartmouth, Team S3-G4, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S3G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 972
