Ana içeriğe geç
Smartab STJR700 Screen/Digitizer Replacement
Neye ihtiyacın var
  1. Smartab STJR700 Screen/Digitizer Replacement, Screen/Digitizer: adım 1, 2 resimden 1. Smartab STJR700 Screen/Digitizer Replacement, Screen/Digitizer: adım 1, 2 resimden 2.
    • There are four screws with each one in each corner. Use the screwdriver to unscrew the back or bottom of the device.
  2. Smartab STJR700 Screen/Digitizer Replacement: adım 2, 1 resimden 1.
    • Remove the bottom or back of the device by detaching the black bottom after removing the screws.
    • the front panel should now be exposing the digitizer along with the other electronic components of the device.
  3. Smartab STJR700 Screen/Digitizer Replacement: adım 3, 2 resimden 1. Smartab STJR700 Screen/Digitizer Replacement: adım 3, 2 resimden 2.
    • Next, remove the circuit board from the front panel and screen. This should leave the digitizer and circuit board intact.
    • Afterward, remove the existing damaged glass part of the device from the front panel as shown in the last picture.
    • Finally add a new STJR700 screen and reverse the previous steps to reattach the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tianna Edwards
128 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G4, Botvin Spring 2017 UMass Dartmouth, Team S3-G4, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S3G4
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 1,261
