Ana içeriğe geç
Smartab STJR700 Speakers Replacement
Neye ihtiyacın var
  1. Smartab STJR700 Speakers Replacement, Speakers: adım 1, 3 resimden 1. Smartab STJR700 Speakers Replacement, Speakers: adım 1, 3 resimden 2. Smartab STJR700 Speakers Replacement, Speakers: adım 1, 3 resimden 3.
    • Power off device. Place it face down. Unscrew the 4 perimeter screws, using a PH000 screwdriver from iFixit kit
  2. Smartab STJR700 Speakers Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool or metal spudger, begin to gently pry the rear case down and away from the display.Slowly wiggle the tool up and down to pry open the tablet.Once the rear case is fully removed place it to the side.
  3. Smartab STJR700 Speakers Replacement: adım 3, 3 resimden 1. Smartab STJR700 Speakers Replacement: adım 3, 3 resimden 2. Smartab STJR700 Speakers Replacement: adım 3, 3 resimden 3.
    • Using tweezers carefully remove tape that is holding the black and red intertwined cables to the motherboard. Place tape to the side as is will be needed for reassembly.
  4. Smartab STJR700 Speakers Replacement: adım 4, 1 resimden 1.
    • Remove the 2 screws holding the speaker to the front panel. Use a PH000 screwdriver from iFixit kit. Place the screws to the side as they will be needed for reassembly.
  5. Smartab STJR700 Speakers Replacement: adım 5, 1 resimden 1.
    • Use the metal spudger to remove the speaker from the front panel of the tablet.
  6. Smartab STJR700 Speakers Replacement: adım 6, 1 resimden 1.
    • Disconnect black and red intertwined wire from the motherboard.
Sonuç
Moriah Wiggins
201 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G4, Botvin Spring 2017 UMass Dartmouth, Team S3-G4, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S3G4
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 179
