Ana içeriğe geç
Snapfōn ezONE LCD Screen Replacement
Neye ihtiyacın var
  1. Snapfōn ezONE LCD Screen Replacement, Remove the battery cover: adım 1, 1 resimden 1.
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfōn ezONE LCD Screen Replacement, Remove the battery: adım 2, 1 resimden 1.
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfōn ezONE LCD Screen Replacement, Removing the plastic inserts: adım 3, 2 resimden 1. Snapfōn ezONE LCD Screen Replacement, Removing the plastic inserts: adım 3, 2 resimden 2.
    • Remove the four rubber inserts from the screw holes using a pair of tweezers.
  4. Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: adım 4, 3 resimden 1. Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: adım 4, 3 resimden 2. Snapfōn ezONE LCD Screen Replacement, Remove the shield screws: adım 4, 3 resimden 3.
    • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
  5. Snapfōn ezONE LCD Screen Replacement, Separate the case: adım 5, 3 resimden 1. Snapfōn ezONE LCD Screen Replacement, Separate the case: adım 5, 3 resimden 2. Snapfōn ezONE LCD Screen Replacement, Separate the case: adım 5, 3 resimden 3.
    • Separate the front case from the back case.
    • Remove the metal bumper from the front case’s perimeter.
  6. Snapfōn ezONE LCD Screen Replacement, Remove the volume slider: adım 6, 1 resimden 1.
    • Pry the volume slider button out with tweezers.
    • The volume slider button may fall out during the separation of the front and back cases. This is OK.
  7. Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: adım 7, 3 resimden 1. Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: adım 7, 3 resimden 2. Snapfōn ezONE LCD Screen Replacement, Remove the motherboard: adım 7, 3 resimden 3.
    • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
    • The last picture is a view of the back of the circuit board.
  8. Snapfōn ezONE LCD Screen Replacement, Pry the screen back: adım 8, 3 resimden 1. Snapfōn ezONE LCD Screen Replacement, Pry the screen back: adım 8, 3 resimden 2. Snapfōn ezONE LCD Screen Replacement, Pry the screen back: adım 8, 3 resimden 3.
    • Pry the LCD screen off of the circuit board using the opening tool. The screen is connected to the motherboard with light adhesive, which is easy to remove.
    • The LCD screen will still be connected to the circuit board by a ribbon cable.
  9. Snapfōn ezONE LCD Screen Replacement, Disconnect the display: adım 9, 1 resimden 1.
    • Use a soldering iron to melt away the connection between the ribbon cable and circuit board.
    • Be careful! High temperatures from the soldering iron may result in injury.
    • Only make contact with the solder connection so that none of the phone’s components are damaged by the heat.
  10. Snapfōn ezONE LCD Screen Replacement, Remove the display: adım 10, 2 resimden 1. Snapfōn ezONE LCD Screen Replacement, Remove the display: adım 10, 2 resimden 2.
    • Once you heat the solder connection, lightly tug the ribbon cable free. The LCD screen will be completely removed from the device.
Sonuç
To reassemble your device with a new LCD screen, follow these instructions in reverse order.
Note: you will need to use the soldering iron again to attach the new LCD screen ribbon to the circuit board.
Bir başkası bu kılavuzu tamamladı.
John Bender
818 İtibar
8 adet Kılavuz yazıldı
Ekip
Clemson, Team 6-5, Benson Spring 2014 Clemson, Team 6-5, Benson Spring 2014 üyesi
CLEM-BENSON-S14S6G5
3 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 10
Her zaman: 436
