Ana içeriğe geç
Snapfon ez One SIM Card Replacement
Neye ihtiyacın var
  1. Snapfon ez One SIM Card Replacement, Remove the battery cover: adım 1, 1 resimden 1.
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfon ez One SIM Card Replacement, Remove the battery: adım 2, 1 resimden 1.
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfon ez One SIM Card Replacement, SIM Card: adım 3, 1 resimden 1.
    • Use the tweezers,if needed, to grasp the SIM card for removal. Apply a slight pulling tension and remove it from under the tabs as shown.
Sonuç
To reinsert the SIM card or a new SIM card, position the card in the same orientation seen in the figure with the brass connections facing the phone while using thumb to apply a slight force until the card rest inside of the recessed holder. Make sure the brass contacts of the card and phone connect. Then follow the steps in reverse order to reassemble phone.
John Bender
818 İtibar
8 adet Kılavuz yazıldı
Ekip
Clemson, Team 6-5, Benson Spring 2014 Clemson, Team 6-5, Benson Spring 2014 üyesi
CLEM-BENSON-S14S6G5
3 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 10
Her zaman: 1,151
