Giriş
The speaker is the component of the phone that allows the user to hear sound emitted from the device. The speaker is part of the system that converts electrical signals into sound waves.
If the speaker from your Snapfon ezOne phone isn't working, follow this guide to replace it.
Neye ihtiyacın var
Turn off the phone to prevent data loss.
Press and slide the battery out to remove it.
Remove the four rubber inserts from the screw holes using a pair of tweezers.
Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
Separate the front case from the back case.
Remove the metal bumper from the front case’s perimeter.
Separate the circuit board from the inside of the back case by prying between them with the opening tool.
The last picture is a view of the back of the circuit board.
