Ana içeriğe geç
Snapfon ezOne Speaker Replacement
Neye ihtiyacın var
  1. Snapfon ezOne Speaker Replacement, Remove the battery cover: adım 1, 1 resimden 1.
    • Turn off the phone to prevent data loss.
    • Press and slide the battery out to remove it.
    • Picture rights belong to Snapfon®. Picture is used for educational purposes only. No copyright infringement intended.
  2. Snapfon ezOne Speaker Replacement, Remove the battery: adım 2, 1 resimden 1.
    • Pry the battery out with your thumb or the iFixit opening tool.
    • Make sure to properly dispose of the old battery at a recycling center.
  3. Snapfon ezOne Speaker Replacement, Removing the plastic inserts: adım 3, 2 resimden 1. Snapfon ezOne Speaker Replacement, Removing the plastic inserts: adım 3, 2 resimden 2.
    • Remove the four rubber inserts from the screw holes using a pair of tweezers.
  4. Snapfon ezOne Speaker Replacement, Remove the shield screws: adım 4, 3 resimden 1. Snapfon ezOne Speaker Replacement, Remove the shield screws: adım 4, 3 resimden 2. Snapfon ezOne Speaker Replacement, Remove the shield screws: adım 4, 3 resimden 3.
    • Remove the four 3.1mm screws in the corners with a Phillips #00 screwdriver.
  5. Snapfon ezOne Speaker Replacement, Separate the case: adım 5, 3 resimden 1. Snapfon ezOne Speaker Replacement, Separate the case: adım 5, 3 resimden 2. Snapfon ezOne Speaker Replacement, Separate the case: adım 5, 3 resimden 3.
    • Separate the front case from the back case.
    • Remove the metal bumper from the front case’s perimeter.
  6. Snapfon ezOne Speaker Replacement, Remove the volume slider: adım 6, 1 resimden 1.
    • Pry the volume slider button out with tweezers.
    • The volume slider button may fall out during the separation of the front and back cases. This is OK.
  7. Snapfon ezOne Speaker Replacement, Remove the motherboard: adım 7, 3 resimden 1. Snapfon ezOne Speaker Replacement, Remove the motherboard: adım 7, 3 resimden 2. Snapfon ezOne Speaker Replacement, Remove the motherboard: adım 7, 3 resimden 3.
    • Separate the circuit board from the inside of the back case by prying between them with the opening tool.
    • The last picture is a view of the back of the circuit board.
  8. Snapfon ezOne Speaker Replacement, Speaker: adım 8, 2 resimden 1. Snapfon ezOne Speaker Replacement, Speaker: adım 8, 2 resimden 2.
    • Remove SOS button from circuit board with tweezers.
  9. Snapfon ezOne Speaker Replacement: adım 9, 3 resimden 1. Snapfon ezOne Speaker Replacement: adım 9, 3 resimden 2. Snapfon ezOne Speaker Replacement: adım 9, 3 resimden 3.
    • Pull black casing from the circuit board with fingers.
    • The black casing will not be able to be fully removed at this point
    • To fully remove the black casing, desolder the SOS button cable from the circuit board with a soldering iron.
    • The solder iron creates high temperatures that may cause bodily harm.
    • Once the black casing is removed, the speaker will now be exposed.
  10. Snapfon ezOne Speaker Replacement: adım 10, 3 resimden 1. Snapfon ezOne Speaker Replacement: adım 10, 3 resimden 2. Snapfon ezOne Speaker Replacement: adım 10, 3 resimden 3.
    • With the plastic opening tools, pry off the speaker from the circuit board.
  11. Snapfon ezOne Speaker Replacement: adım 11, 2 resimden 1. Snapfon ezOne Speaker Replacement: adım 11, 2 resimden 2.
    • Desolder the speaker cables from the base of the circuit board with the soldering iron.
    • The soldering iron creates high temperatures that may cause bodily harm.
    • Melt the new speaker wires to the circuit board with the soldering iron.
Sonuç
John Bender
818 İtibar
8 adet Kılavuz yazıldı
Ekip
Clemson, Team 6-5, Benson Spring 2014 Clemson, Team 6-5, Benson Spring 2014 üyesi
CLEM-BENSON-S14S6G5
3 Üyeler
16 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 8
Her zaman: 311
