Ana içeriğe geç
Snow Blower Shear Bolt Replacement
Neye ihtiyacın var
  1. Snow Blower Shear Bolt Replacement, Locate new shear bolt: adım 1, 1 resimden 1.
    • The new shear bolt is stored on the top of the auger discharge
  2. Snow Blower Shear Bolt Replacement, Remove the old shear bolt: adım 2, 3 resimden 1. Snow Blower Shear Bolt Replacement, Remove the old shear bolt: adım 2, 3 resimden 2. Snow Blower Shear Bolt Replacement, Remove the old shear bolt: adım 2, 3 resimden 3.
    • The shear bolt attaches the auger to the shaft
    • The shear bolt is designed to break preventing damage to the auger and shaft if an hard object is pulled in
    • Locate the side with the missing shear bolt
    • The left side is missing
    • This auger will spin freely on this side
    • Rotate the auger to find where the bolt is on the shaft
  3. Snow Blower Shear Bolt Replacement: adım 3, 2 resimden 1. Snow Blower Shear Bolt Replacement: adım 3, 2 resimden 2.
    • Use the new shear bolt to push the old broken bolt out of the shaft
    • It should fall out and look like this
  4. Snow Blower Shear Bolt Replacement: adım 4, 2 resimden 1. Snow Blower Shear Bolt Replacement: adım 4, 2 resimden 2.
    • With the new bolt in place from pushing the old bolt out add a nut
    • Hand tighten
  5. Snow Blower Shear Bolt Replacement: adım 5, 2 resimden 1. Snow Blower Shear Bolt Replacement: adım 5, 2 resimden 2.
    • Using two 7/16" wrenches tighten the nut on the bolt
    • Do not over tighten
    • Congratulations, both shear bolts have been replaced
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jacob Rattray
263 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 33
Her zaman: 1,661
