Ana içeriğe geç
Snowboard Binding Replacement
Neye ihtiyacın var
  1. Snowboard Binding Replacement, Binding: adım 1, 3 resimden 1. Snowboard Binding Replacement, Binding: adım 1, 3 resimden 2. Snowboard Binding Replacement, Binding: adım 1, 3 resimden 3.
    • Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
    • Not all binding straps will release the same way. If you are having trouble releasing your binding straps, please refer to your owner's manual.
    FixBot'a Sor
    Yorum Ekle
  2. Snowboard Binding Replacement: adım 2, 2 resimden 1. Snowboard Binding Replacement: adım 2, 2 resimden 2.
    • Move the straps and the highback plate out of the way in order to have clear access to the foot pad screw.
    • The highback plate is the vertical support plate located on the heel side of the binding.
    FixBot'a Sor
    Yorum Ekle
  3. Snowboard Binding Replacement: adım 3, 2 resimden 1. Snowboard Binding Replacement: adım 3, 2 resimden 2.
    • Use a #2 Phillips screwdriver to remove the panhead, 10mm wide, M4 x 12mm screw located in the middle of the foot pad.
    FixBot'a Sor
    Yorum Ekle
  4. Snowboard Binding Replacement: adım 4, 3 resimden 1. Snowboard Binding Replacement: adım 4, 3 resimden 2. Snowboard Binding Replacement: adım 4, 3 resimden 3.
    • Use a #2 Phillips screwdriver to remove the four ovalhead M6 x 12mm screws that attach the base plate of the binding to the board.
    • Lift or slide the binding off the board and set the screws aside.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Loren Sunding
118 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-4, Forte Winter 2014 Cal Poly, Team 17-4, Forte Winter 2014 üyesi
CPSU-FORTE-W14S17G4
5 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 51
Her zaman: 16,880
