Ana içeriğe geç
Snowboard Binding Strap Replacement
Neye ihtiyacın var
  1. Snowboard Binding Strap Replacement, Binding: adım 1, 3 resimden 1. Snowboard Binding Strap Replacement, Binding: adım 1, 3 resimden 2. Snowboard Binding Strap Replacement, Binding: adım 1, 3 resimden 3.
    • Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
    • Not all binding straps will release the same way. If you are having trouble releasing your binding straps, please refer to your owner's manual.
    FixBot'a Sor
    Yorum Ekle
  2. Snowboard Binding Strap Replacement: adım 2, 2 resimden 1. Snowboard Binding Strap Replacement: adım 2, 2 resimden 2.
    • Move the straps and the highback plate out of the way in order to have clear access to the foot pad screw.
    • The highback plate is the vertical support plate located on the heel side of the binding.
    FixBot'a Sor
    Yorum Ekle
  3. Snowboard Binding Strap Replacement: adım 3, 2 resimden 1. Snowboard Binding Strap Replacement: adım 3, 2 resimden 2.
    • Use a #2 Phillips screwdriver to remove the panhead, 10mm wide, M4 x 12mm screw located in the middle of the foot pad.
    FixBot'a Sor
    Yorum Ekle
  4. Snowboard Binding Strap Replacement: adım 4, 3 resimden 1. Snowboard Binding Strap Replacement: adım 4, 3 resimden 2. Snowboard Binding Strap Replacement: adım 4, 3 resimden 3.
    • Use a #2 Phillips screwdriver to remove the four ovalhead M6 x 12mm screws that attach the base plate of the binding to the board.
    • Lift or slide the binding off the board and set the screws aside.
    FixBot'a Sor
    Yorum Ekle
  5. Snowboard Binding Strap Replacement, Binding Strap: adım 5, 3 resimden 1. Snowboard Binding Strap Replacement, Binding Strap: adım 5, 3 resimden 2. Snowboard Binding Strap Replacement, Binding Strap: adım 5, 3 resimden 3.
    • Use a 5.5mm flathead screwdriver to anchor the backing bracket located on the inside of the binding.
    • Using a Phillips #2 screwdriver, unscrew the countersunk ovalhead M4 x 16mm screw connecting the heel strap ladder to the binding.
    FixBot'a Sor
    Yorum Ekle
  6. Snowboard Binding Strap Replacement: adım 6, 2 resimden 1. Snowboard Binding Strap Replacement: adım 6, 2 resimden 2.
    • Unscrew the 10mm long thumb screw connecting the heel strap with its binding connector.
    • Pull the heel strap apart from its binding connector.
    FixBot'a Sor
    Yorum Ekle
  7. Snowboard Binding Strap Replacement: adım 7, 3 resimden 1. Snowboard Binding Strap Replacement: adım 7, 3 resimden 2. Snowboard Binding Strap Replacement: adım 7, 3 resimden 3.
    • Using a Phillips #2 screwdriver, locate and unscrew the countersunk ovalhead M4 x 16mm screw holding the heel strap connector to the binding.
    FixBot'a Sor
    Yorum Ekle
  8. Snowboard Binding Strap Replacement: adım 8, 2 resimden 1. Snowboard Binding Strap Replacement: adım 8, 2 resimden 2.
    • Flip the binding so that the bottom is accessible.
    • Using your hands, pry off the plastic bottom covering starting at the toe end.
    • The bottom may still remain attached on the heel edge. There is no need to completely remove it.
    FixBot'a Sor
    Yorum Ekle
  9. Snowboard Binding Strap Replacement: adım 9, 3 resimden 1. Snowboard Binding Strap Replacement: adım 9, 3 resimden 2. Snowboard Binding Strap Replacement: adım 9, 3 resimden 3.
    • Remove the corner foam coverings by grabbing one edge and lifting up.
    • Slide out the toe strap ladder.
    FixBot'a Sor
    Yorum Ekle
  10. Snowboard Binding Strap Replacement: adım 10, 3 resimden 1. Snowboard Binding Strap Replacement: adım 10, 3 resimden 2. Snowboard Binding Strap Replacement: adım 10, 3 resimden 3.
    • Using a Phillips #2 screwdriver, unscrew the button head M4 x 10mm screw holding the toe strap with its connector.
    • Slide the toe strap off of the toe strap connector.
    FixBot'a Sor
    Yorum Ekle
  11. Snowboard Binding Strap Replacement: adım 11, 2 resimden 1. Snowboard Binding Strap Replacement: adım 11, 2 resimden 2.
    • Turn the binding on its side and slide out the toe strap connector.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Robert Torres
214 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 17-4, Forte Winter 2014 Cal Poly, Team 17-4, Forte Winter 2014 üyesi
CPSU-FORTE-W14S17G4
5 Üyeler
11 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 11
Son 30 gün: 79
Her zaman: 51,392
