Ana içeriğe geç
Snowboard Traction Pad Replacement
Neye ihtiyacın var
  1. Snowboard Traction Pad Replacement, Traction Pad: adım 1, 2 resimden 1. Snowboard Traction Pad Replacement, Traction Pad: adım 1, 2 resimden 2.
    • Use a plastic or metal scraper to remove the existing traction pad.
  2. Snowboard Traction Pad Replacement: adım 2, 3 resimden 1. Snowboard Traction Pad Replacement: adım 2, 3 resimden 2. Snowboard Traction Pad Replacement: adım 2, 3 resimden 3.
    • If there is any residual adhesive left from the old traction pad, soak it with adhesive remover.
    • Let the adhesive remover sit for a few minutes.
    • Wipe away the residue using a towel and water.
    • Dry the the surface where the new traction pad will be placed.
  3. Snowboard Traction Pad Replacement: adım 3, 3 resimden 1. Snowboard Traction Pad Replacement: adım 3, 3 resimden 2. Snowboard Traction Pad Replacement: adım 3, 3 resimden 3.
    • Peel the back off of the new traction pad to reveal the adhesive.
    • When placed, the traction pad should be about an inch away from the rear binding.
    • To avoid creating air bubbles, start with one corner of the pad and roll the rest down.
    • Press down firmly to help it stick to the board and remove any air bubbles that may have occurred.
    • Give the adhesive a minimum of 12 hours to dry before use.
Bitiş Çizgisi
Jacob Garcia
101 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 17-4, Forte Winter 2014 Cal Poly, Team 17-4, Forte Winter 2014 üyesi
CPSU-FORTE-W14S17G4
5 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 13
Her zaman: 3,637
