Ana içeriğe geç
SodaStream Fountain Jet A200 Spring Replacement
  1. SodaStream Fountain Jet A200 Spring Replacement, removing back cover: adım 1, 2 resimden 1. SodaStream Fountain Jet A200 Spring Replacement, removing back cover: adım 1, 2 resimden 2.
    • Press in the two gray buttons found on either side, at the top of the machine.
    • Pull back on the cover until it releases from the device and pull the back off.
  2. SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: adım 2, 2 resimden 1. SodaStream Fountain Jet A200 Spring Replacement, Carbonation button: adım 2, 2 resimden 2.
    • Place your hand under the carbonation button and gently pull up and away from you, towards the back of the machine.
  3. SodaStream Fountain Jet A200 Spring Replacement, spring removal: adım 3, 2 resimden 1. SodaStream Fountain Jet A200 Spring Replacement, spring removal: adım 3, 2 resimden 2.
    • Remove the spring located under the carbonation button.
    • Replace with the new spring, by lining it up and pushing it down.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
2 Yorum
Does anyone know where I can get a carbonation button?
draganr@wi.rr.com
draganr - Yanıt
Do we know the spring parameters?
Outside Diameter
Inside Diameter
Overall Length
Wire Diameter
Total # of Coils
Active # of Coils
Solid Height
Space between the Coils
John Friedman - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 15
Son 30 gün: 41
Her zaman: 9,902
