Ana içeriğe geç
SodaStream Source Battery Replacement
Neye ihtiyacın var
    1. SodaStream Source Battery Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 1. SodaStream Source Battery Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 2. SodaStream Source Battery Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 3.
      • Remove the soda bottle and the CO₂ canister from the machine.
      FixBot'a Sor
      Yorum Ekle
    2. SodaStream Source Battery Replacement: adım 2, 2 resimden 1. SodaStream Source Battery Replacement: adım 2, 2 resimden 2.
      Bu adımda kullanılan alet:
      Phillips #1 Screwdriver
      $8.99
      FixBot'a Sor
      Yorum Ekle
    3. SodaStream Source Battery Replacement: adım 3, 2 resimden 1. SodaStream Source Battery Replacement: adım 3, 2 resimden 2.
      • Pull the outer cover away from the front of the device.
      FixBot'a Sor
      Yorum Ekle
    4. SodaStream Source Battery Replacement: adım 4, 1 resimden 1.
      $8.99
      FixBot'a Sor
      Yorum Ekle
    5. SodaStream Source Battery Replacement: adım 5, 2 resimden 1. SodaStream Source Battery Replacement: adım 5, 2 resimden 2.
      Jimmy
      $7.95
      • Firmly pull the front cover off.
      • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
      FixBot'a Sor
      Yorum Ekle
    1. SodaStream Source Battery Replacement, Battery: adım 6, 2 resimden 1. SodaStream Source Battery Replacement, Battery: adım 6, 2 resimden 2.
      • Remove the old battery and replace it with a new 3V lithium battery.
      FixBot'a Sor
      Yorum Ekle
Sonuç
30 farklı kişi bu kılavuzu tamamladı.
Alexandra I Curtis
1.151 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Leahy Spring 2017 USF Tampa, Team S1-G4, Leahy Spring 2017 üyesi
USFT-LEAHY-S17S1G4
3 Üyeler
48 adet Kılavuz yazıldı
22Kılavuz Yorumları
Heel de achterkant hoeft er hiervoor niet af hoor juist de voorkant 2 vijsjes en je kan het voorste deksel er af klikken ;)
tomclaes1989 - Yanıt Paylaş
Perfectly explained! I was afraid to pull the front cover because it does indeed take a lot of force to pull off!!
its important to note it’s a C123A 3v battery, not the C2 3v as I found out after opening
Kevin Shiner - Yanıt Paylaş
Where is the best place to find these batteries? Canadian tire?
Dancingdaisy007 S - Yanıt Paylaş
Its the same battery many many products use usually built in , motherboards used it for years.
Kal Jak - Yanıt Paylaş
Staples has the 123A 3v battery
scottvelasco - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 38
Son 7 gün: 186
Son 30 gün: 964
Her zaman: 116,667
