Ana içeriğe geç
SodaStream Source Internal Carbonation Air Hose Replacement
Neye ihtiyacın var
    1. SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 2. SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 3.
      • Remove the soda bottle and the CO₂ canister from the machine.
      FixBot'a Sor
      Yorum Ekle
    2. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 2, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 2, 2 resimden 2.
      Bu adımda kullanılan alet:
      Phillips #1 Screwdriver
      $8.99
      FixBot'a Sor
      Yorum Ekle
    3. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 3, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 3, 2 resimden 2.
      • Pull the outer cover away from the front of the device.
      FixBot'a Sor
      Yorum Ekle
    4. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 4, 1 resimden 1.
      $8.99
      FixBot'a Sor
      Yorum Ekle
    5. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 5, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 5, 2 resimden 2.
      Jimmy
      $7.95
      • Firmly pull the front cover off.
      • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
      FixBot'a Sor
      Yorum Ekle
    1. SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source  Internal Disassembly: adım 6, 3 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source  Internal Disassembly: adım 6, 3 resimden 2. SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source  Internal Disassembly: adım 6, 3 resimden 3.
      • Push the brass bar, located in the top of the device, out of the carbonating block.
      • You can use the end of your screwdriver to push this piece out.
      FixBot'a Sor
      Yorum Ekle
    2. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 7, 3 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 7, 3 resimden 2. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 7, 3 resimden 3.
      • Slide the yellow battery cover up and away to remove it from the device.
      FixBot'a Sor
      Yorum Ekle
    3. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 8, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 8, 2 resimden 2.
      • Unhook the bottom piece of the plastic arm on each side of the device.
      FixBot'a Sor
      Yorum Ekle
    4. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 9, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 9, 2 resimden 2.
      • Lift the top of the plastic arm with the spudger and remove it on both sides.
      FixBot'a Sor
      Yorum Ekle
    5. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 10, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 10, 2 resimden 2.
      • Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
      FixBot'a Sor
      Yorum Ekle
    6. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 11, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 11, 2 resimden 2.
      • Remove the plastic oval and the spring within it.
      FixBot'a Sor
      Yorum Ekle
    7. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 12, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 12, 2 resimden 2.
      • Pull the loader tab cover down and away from the rest of the carbonating block.
      FixBot'a Sor
      Yorum Ekle
    8. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 13, 1 resimden 1.
      • Remove the three 17.9 mm screws located on the right side.
      • These screws may be difficult to access.
      FixBot'a Sor
      Yorum Ekle
    9. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 14, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 14, 2 resimden 2.
      • Unhook the four clips on the top of the carbonating block and remove the plastic cover.
      FixBot'a Sor
      Yorum Ekle
    10. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 15, 3 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 15, 3 resimden 2. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 15, 3 resimden 3.
      • Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
      FixBot'a Sor
      Yorum Ekle
    11. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 16, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 16, 2 resimden 2.
      • Unhook the silver spring arms on both sides of the device by pushing down.
      FixBot'a Sor
      Yorum Ekle
    12. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 17, 1 resimden 1.
      • Grip the right and left sides of the device and pull it into two identical halves.
      • Once these two pieces are apart, all remaining internal components will fall out of the device.
      FixBot'a Sor
      Yorum Ekle
    13. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 18, 3 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 18, 3 resimden 2. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 18, 3 resimden 3.
      • Pull the foam pad up and remove it from the front side of the carbonation component.
      FixBot'a Sor
      Yorum Ekle
    14. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 19, 1 resimden 1.
      • Remove the six 17.7 mm screws from the underside of the loader tab piece.
      FixBot'a Sor
      Yorum Ekle
    15. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 20, 3 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 20, 3 resimden 2. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 20, 3 resimden 3.
      • Pull the loader tab out of the nozzle.
      FixBot'a Sor
      Yorum Ekle
    1. SodaStream Source Internal Carbonation Air Hose  Replacement, Internal Carbonation Air Hose: adım 21, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement, Internal Carbonation Air Hose: adım 21, 2 resimden 2.
      • Use pliers to unscrew the gold cap piece from both ends of the tube
      FixBot'a Sor
      Yorum Ekle
    2. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 22, 3 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 22, 3 resimden 2. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 22, 3 resimden 3.
      • Detach the hose from both sides of the carbonation system.
      • You will have to use force to detach this piece.
      FixBot'a Sor
      Yorum Ekle
Sonuç
26 farklı kişi bu kılavuzu tamamladı.
Hailey Smith
1.591 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Leahy Spring 2017 USF Tampa, Team S1-G4, Leahy Spring 2017 üyesi
USFT-LEAHY-S17S1G4
3 Üyeler
48 adet Kılavuz yazıldı
71Kılavuz Yorumları
Thanks for the guide, but i currently have this issue where the hose needs to be replaced, but no way of sourcing a spare part? Any clues anyone?
Nathan Roberts - Yanıt Paylaş
Did you ever find the part for your machine?
nagjoinslipknot - Yanıt Paylaş
Where would you get this part
magnolia_ca - Yanıt Paylaş
Exactly the same problem on my Source, but I can't find spare parts anywhere.
Has anyone found where to get them from in Australia?
did you ever find a supplier for the air hose replacement?
mark.jc.wright - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 40
Son 7 gün: 255
Son 30 gün: 1,111
Her zaman: 83,632
