Ana içeriğe geç
SodaStream Source Internal Carbonation Air Hose Replacement
Neye ihtiyacın var
  1. SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 2. SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 3.
    • Remove the soda bottle and the CO₂ canister from the machine.
  2. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 2, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Phillips #1 Screwdriver
    $8.99
  3. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 3, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 3, 2 resimden 2.
    • Pull the outer cover away from the front of the device.
  4. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 4, 1 resimden 1.
    $8.99
  5. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 5, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 5, 2 resimden 2.
    Jimmy
    $7.95
    • Firmly pull the front cover off.
    • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
  6. SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source  Internal Disassembly: adım 6, 3 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source  Internal Disassembly: adım 6, 3 resimden 2. SodaStream Source Internal Carbonation Air Hose  Replacement, SodaStream Source  Internal Disassembly: adım 6, 3 resimden 3.
    • Push the brass bar, located in the top of the device, out of the carbonating block.
    • You can use the end of your screwdriver to push this piece out.
  7. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 7, 3 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 7, 3 resimden 2. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 7, 3 resimden 3.
    • Slide the yellow battery cover up and away to remove it from the device.
  8. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 8, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 8, 2 resimden 2.
    • Unhook the bottom piece of the plastic arm on each side of the device.
  9. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 9, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 9, 2 resimden 2.
    • Lift the top of the plastic arm with the spudger and remove it on both sides.
  10. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 10, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 10, 2 resimden 2.
    • Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
  11. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 11, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 11, 2 resimden 2.
    • Remove the plastic oval and the spring within it.
  12. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 12, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 12, 2 resimden 2.
    • Pull the loader tab cover down and away from the rest of the carbonating block.
  13. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 13, 1 resimden 1.
    • Remove the three 17.9 mm screws located on the right side.
    • These screws may be difficult to access.
  14. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 14, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 14, 2 resimden 2.
    • Unhook the four clips on the top of the carbonating block and remove the plastic cover.
  15. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 15, 3 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 15, 3 resimden 2. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 15, 3 resimden 3.
    • Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
  16. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 16, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 16, 2 resimden 2.
    • Unhook the silver spring arms on both sides of the device by pushing down.
  17. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 17, 1 resimden 1.
    • Grip the right and left sides of the device and pull it into two identical halves.
    • Once these two pieces are apart, all remaining internal components will fall out of the device.
  18. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 18, 3 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 18, 3 resimden 2. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 18, 3 resimden 3.
    • Pull the foam pad up and remove it from the front side of the carbonation component.
  19. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 19, 1 resimden 1.
    • Remove the six 17.7 mm screws from the underside of the loader tab piece.
  20. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 20, 3 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 20, 3 resimden 2. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 20, 3 resimden 3.
    • Pull the loader tab out of the nozzle.
  21. SodaStream Source Internal Carbonation Air Hose  Replacement, Internal Carbonation Air Hose: adım 21, 2 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement, Internal Carbonation Air Hose: adım 21, 2 resimden 2.
    • Use pliers to unscrew the gold cap piece from both ends of the tube
  22. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 22, 3 resimden 1. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 22, 3 resimden 2. SodaStream Source Internal Carbonation Air Hose  Replacement: adım 22, 3 resimden 3.
    • Detach the hose from both sides of the carbonation system.
    • You will have to use force to detach this piece.
Sonuç
22 farklı kişi bu kılavuzu tamamladı.
Hailey Smith
1.408 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Leahy Spring 2017 USF Tampa, Team S1-G4, Leahy Spring 2017 üyesi
USFT-LEAHY-S17S1G4
3 Üyeler
41 adet Kılavuz yazıldı
66Kılavuz Yorumları
Thanks for the guide, but i currently have this issue where the hose needs to be replaced, but no way of sourcing a spare part? Any clues anyone?
Nathan Roberts - Yanıt
Did you ever find the part for your machine?
nagjoinslipknot -
Where would you get this part
magnolia_ca - Yanıt
Exactly the same problem on my Source, but I can't find spare parts anywhere.
Has anyone found where to get them from in Australia?
nagjoinslipknot - Yanıt
did you ever find a supplier for the air hose replacement?
mark.jc.wright -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 29
Son 7 gün: 181
Son 30 gün: 879
Her zaman: 66,738
