Ana içeriğe geç
SodaStream Source Loader Tab Replacement
Neye ihtiyacın var
  1. SodaStream Source Loader Tab Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 1. SodaStream Source Loader Tab Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 2. SodaStream Source Loader Tab Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 3.
    • Remove the soda bottle and the CO₂ canister from the machine.
    FixBot'a Sor
    Yorum Ekle
  2. SodaStream Source Loader Tab Replacement: adım 2, 2 resimden 1. SodaStream Source Loader Tab Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Phillips #1 Screwdriver
    $8.99
    FixBot'a Sor
    Yorum Ekle
  3. SodaStream Source Loader Tab Replacement: adım 3, 2 resimden 1. SodaStream Source Loader Tab Replacement: adım 3, 2 resimden 2.
    • Pull the outer cover away from the front of the device.
    FixBot'a Sor
    Yorum Ekle
  4. SodaStream Source Loader Tab Replacement: adım 4, 1 resimden 1.
    $8.99
    FixBot'a Sor
    Yorum Ekle
  5. SodaStream Source Loader Tab Replacement: adım 5, 2 resimden 1. SodaStream Source Loader Tab Replacement: adım 5, 2 resimden 2.
    Jimmy
    $7.95
    • Firmly pull the front cover off.
    • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
    FixBot'a Sor
    Yorum Ekle
  6. SodaStream Source Loader Tab Replacement, SodaStream Source  Internal Disassembly: adım 6, 3 resimden 1. SodaStream Source Loader Tab Replacement, SodaStream Source  Internal Disassembly: adım 6, 3 resimden 2. SodaStream Source Loader Tab Replacement, SodaStream Source  Internal Disassembly: adım 6, 3 resimden 3.
    • Push the brass bar, located in the top of the device, out of the carbonating block.
    • You can use the end of your screwdriver to push this piece out.
    FixBot'a Sor
    Yorum Ekle
  7. SodaStream Source Loader Tab Replacement: adım 7, 3 resimden 1. SodaStream Source Loader Tab Replacement: adım 7, 3 resimden 2. SodaStream Source Loader Tab Replacement: adım 7, 3 resimden 3.
    • Slide the yellow battery cover up and away to remove it from the device.
    FixBot'a Sor
    Yorum Ekle
  8. SodaStream Source Loader Tab Replacement: adım 8, 2 resimden 1. SodaStream Source Loader Tab Replacement: adım 8, 2 resimden 2.
    • Unhook the bottom piece of the plastic arm on each side of the device.
    FixBot'a Sor
    Yorum Ekle
  9. SodaStream Source Loader Tab Replacement: adım 9, 2 resimden 1. SodaStream Source Loader Tab Replacement: adım 9, 2 resimden 2.
    • Lift the top of the plastic arm with the spudger and remove it on both sides.
    FixBot'a Sor
    Yorum Ekle
  10. SodaStream Source Loader Tab Replacement: adım 10, 2 resimden 1. SodaStream Source Loader Tab Replacement: adım 10, 2 resimden 2.
    • Remove the plastic piece, located near the front of the carbonating block, from both sides of the device using a plastic opening tool or nylon spudger.
    FixBot'a Sor
    Yorum Ekle
  11. SodaStream Source Loader Tab Replacement: adım 11, 2 resimden 1. SodaStream Source Loader Tab Replacement: adım 11, 2 resimden 2.
    • Remove the plastic oval and the spring within it.
    FixBot'a Sor
    Yorum Ekle
  12. SodaStream Source Loader Tab Replacement: adım 12, 2 resimden 1. SodaStream Source Loader Tab Replacement: adım 12, 2 resimden 2.
    • Pull the loader tab cover down and away from the rest of the carbonating block.
    FixBot'a Sor
    Yorum Ekle
  13. SodaStream Source Loader Tab Replacement: adım 13, 1 resimden 1.
    • Remove the three 17.9 mm screws located on the right side.
    • These screws may be difficult to access.
    FixBot'a Sor
    Yorum Ekle
  14. SodaStream Source Loader Tab Replacement: adım 14, 2 resimden 1. SodaStream Source Loader Tab Replacement: adım 14, 2 resimden 2.
    • Unhook the four clips on the top of the carbonating block and remove the plastic cover.
    FixBot'a Sor
    Yorum Ekle
  15. SodaStream Source Loader Tab Replacement: adım 15, 3 resimden 1. SodaStream Source Loader Tab Replacement: adım 15, 3 resimden 2. SodaStream Source Loader Tab Replacement: adım 15, 3 resimden 3.
    • Lift the clips located on both sides with the plastic spudger. Slide the front cover off.
    FixBot'a Sor
    Yorum Ekle
  16. SodaStream Source Loader Tab Replacement: adım 16, 2 resimden 1. SodaStream Source Loader Tab Replacement: adım 16, 2 resimden 2.
    • Unhook the silver spring arms on both sides of the device by pushing down.
    FixBot'a Sor
    Yorum Ekle
  17. SodaStream Source Loader Tab Replacement: adım 17, 1 resimden 1.
    • Grip the right and left sides of the device and pull it into two identical halves.
    • Once these two pieces are apart, all remaining internal components will fall out of the device.
    FixBot'a Sor
    Yorum Ekle
  18. SodaStream Source Loader Tab Replacement: adım 18, 3 resimden 1. SodaStream Source Loader Tab Replacement: adım 18, 3 resimden 2. SodaStream Source Loader Tab Replacement: adım 18, 3 resimden 3.
    • Pull the foam pad up and remove it from the front side of the carbonation component.
    FixBot'a Sor
    Yorum Ekle
  19. SodaStream Source Loader Tab Replacement: adım 19, 1 resimden 1.
    • Remove the six 17.7 mm screws from the underside of the loader tab piece.
    FixBot'a Sor
    Yorum Ekle
  20. SodaStream Source Loader Tab Replacement: adım 20, 3 resimden 1. SodaStream Source Loader Tab Replacement: adım 20, 3 resimden 2. SodaStream Source Loader Tab Replacement: adım 20, 3 resimden 3.
    • Pull the loader tab out of the nozzle.
    FixBot'a Sor
    Yorum Ekle
  21. SodaStream Source Loader Tab Replacement, Loader Tab: adım 21, 3 resimden 1. SodaStream Source Loader Tab Replacement, Loader Tab: adım 21, 3 resimden 2. SodaStream Source Loader Tab Replacement, Loader Tab: adım 21, 3 resimden 3.
    • Pull the small inner plastic circle out of the large plastic loader tab piece.
    FixBot'a Sor
    Yorum Ekle
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Angela Mossgrove
1.198 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Leahy Spring 2017 USF Tampa, Team S1-G4, Leahy Spring 2017 üyesi
USFT-LEAHY-S17S1G4
3 Üyeler
41 adet Kılavuz yazıldı
6Kılavuz Yorumları
Thank you SO much for this! I was having a lot of trouble with this thing not releasing the bottle, so I disassembled it all and put it back together and now it works a treat! Not sure what was going on but I am so excited. You weren’t kidding at the end about it all falling apart… took ages to work out how it all went back together, but now I understand it and I have a working SodaStream. 5*!
Amanda L - Yanıt Paylaş
Do you know where the tiny magnet goes? It fell out on the table as I was disassembling.
cheryl meeks - Yanıt Paylaş
I think it has something to do with the microchip for the LED’s. Can’t figure out how else the light would light. I haven’t taken it apart far enough to find the magnet. Hope this helps you.
Paul Bibeau - Yanıt Paylaş
You can see the magnet in step 18, the first picture. Its right below where a screw used to be.
Tom Green - Yanıt Paylaş
I placed sodastream on side and removed top half. I could then see where parts needed to be after they “fell out” for reassembly. More pictures of those steps would be helpful. Thank
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 14
Son 7 gün: 60
Son 30 gün: 222
Her zaman: 28,967
