Ana içeriğe geç
SodaStream Source Microchip Replacement
Neye ihtiyacın var
  1. SodaStream Source Microchip Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 1. SodaStream Source Microchip Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 2. SodaStream Source Microchip Replacement, SodaStream Source External Disassembly: adım 1, 3 resimden 3.
    • Remove the soda bottle and the CO₂ canister from the machine.
  2. SodaStream Source Microchip Replacement: adım 2, 2 resimden 1. SodaStream Source Microchip Replacement: adım 2, 2 resimden 2.
    Bu adımda kullanılan alet:
    Phillips #1 Screwdriver
    $8.99
  3. SodaStream Source Microchip Replacement: adım 3, 2 resimden 1. SodaStream Source Microchip Replacement: adım 3, 2 resimden 2.
    • Pull the outer cover away from the front of the device.
  4. SodaStream Source Microchip Replacement: adım 4, 1 resimden 1.
    $8.99
  5. SodaStream Source Microchip Replacement: adım 5, 2 resimden 1. SodaStream Source Microchip Replacement: adım 5, 2 resimden 2.
    Jimmy
    $7.95
    • Firmly pull the front cover off.
    • This piece is difficult to remove and requires force. It may help to use a wide, thin object to pry it off (like a Jimmy).
  6. SodaStream Source Microchip Replacement, Microchip: adım 6, 1 resimden 1.
    • Remove the 9.1 mm screw from the microchip.
  7. SodaStream Source Microchip Replacement: adım 7, 3 resimden 1. SodaStream Source Microchip Replacement: adım 7, 3 resimden 2. SodaStream Source Microchip Replacement: adım 7, 3 resimden 3.
    • Wedge the plastic spudger between the microchip and the glue dot until the glue pops off.
  8. SodaStream Source Microchip Replacement: adım 8, 3 resimden 1. SodaStream Source Microchip Replacement: adım 8, 3 resimden 2. SodaStream Source Microchip Replacement: adım 8, 3 resimden 3.
    Spudger
    $2.99
    • Use the spudger to lift the edge of the wire and pull the wire out of the microchip.
    • Use an ESD tool such as a nylon spudger when working with potentially dangerous electronics.
    • While reconnecting the wires, you will need a hot glue gun to reattach the wire ends to the new chip.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Angela Mossgrove
1.180 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Leahy Spring 2017 USF Tampa, Team S1-G4, Leahy Spring 2017 üyesi
USFT-LEAHY-S17S1G4
3 Üyeler
41 adet Kılavuz yazıldı
4Kılavuz Yorumları
Great information, but is there someone out there offering this repair as a service, I’m not motivated enough to do this myself and happy to pay someone to do it for me
matteo barnett - Yanıt Paylaş
Where can you buy the microchip please?
Jill - Yanıt Paylaş
Where can you purchase a replacement microchip from?
David Grosz - Yanıt Paylaş
Where can I find the reassemble source at
mcphersonp411 - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 16
Son 30 gün: 80
Her zaman: 5,786
