Ana içeriğe geç
Softball Glove String Replacement
Neye ihtiyacın var
  1. Softball Glove String Replacement, Softball Glove String: adım 1, 3 resimden 1. Softball Glove String Replacement, Softball Glove String: adım 1, 3 resimden 2. Softball Glove String Replacement, Softball Glove String: adım 1, 3 resimden 3.
    • Tie a knot at one end of the string.
  2. Softball Glove String Replacement: adım 2, 2 resimden 1. Softball Glove String Replacement: adım 2, 2 resimden 2.
    • Put the string through the loop of the leather needle.
  3. Softball Glove String Replacement: adım 3, 2 resimden 1. Softball Glove String Replacement: adım 3, 2 resimden 2.
    • Push the needle through the first hole on the backside of the pinky finger.
  4. Softball Glove String Replacement: adım 4, 3 resimden 1. Softball Glove String Replacement: adım 4, 3 resimden 2. Softball Glove String Replacement: adım 4, 3 resimden 3.
    • Pull the string out of the needle and back the needle out of the hole.
  5. Softball Glove String Replacement: adım 5, 2 resimden 1. Softball Glove String Replacement: adım 5, 2 resimden 2.
    • Pull the string all the way through and reinsert the string into the needle.
  6. Softball Glove String Replacement: adım 6, 2 resimden 1. Softball Glove String Replacement: adım 6, 2 resimden 2.
    • Push the needle through the bottom hole on the ring finger.
    • Pull the string out of the needle and all the way through the hole. Back the needle out of the hole.
  7. Softball Glove String Replacement: adım 7, 3 resimden 1. Softball Glove String Replacement: adım 7, 3 resimden 2. Softball Glove String Replacement: adım 7, 3 resimden 3.
    • Insert the string back into the needle and push it through the bottom hole on the pinky.
    • Pull the string all the way through and remove it from the needle.
  8. Softball Glove String Replacement: adım 8, 3 resimden 1. Softball Glove String Replacement: adım 8, 3 resimden 2. Softball Glove String Replacement: adım 8, 3 resimden 3.
    • Pull the string under the loop, making an X.
  9. Softball Glove String Replacement: adım 9, 3 resimden 1. Softball Glove String Replacement: adım 9, 3 resimden 2. Softball Glove String Replacement: adım 9, 3 resimden 3.
    • Put the string through the needle and push the needle though the top hole on the ring finger.
  10. Softball Glove String Replacement: adım 10, 3 resimden 1. Softball Glove String Replacement: adım 10, 3 resimden 2. Softball Glove String Replacement: adım 10, 3 resimden 3.
    • Going around the back of the ring finger, insert the string through the top hole on the left side of the ring finger.
    • Pull the string all the way through.
  11. Softball Glove String Replacement: adım 11, 3 resimden 1. Softball Glove String Replacement: adım 11, 3 resimden 2. Softball Glove String Replacement: adım 11, 3 resimden 3.
    • Insert the string through the bottom hole on the middle finger.
  12. Softball Glove String Replacement: adım 12, 2 resimden 1. Softball Glove String Replacement: adım 12, 2 resimden 2.
    • Cross over the backside and insert the string into the bottom hole on the left side of the ring finger.
  13. Softball Glove String Replacement: adım 13, 3 resimden 1. Softball Glove String Replacement: adım 13, 3 resimden 2. Softball Glove String Replacement: adım 13, 3 resimden 3.
    • Pull the string under the loop to make an X.
  14. Softball Glove String Replacement: adım 14, 3 resimden 1. Softball Glove String Replacement: adım 14, 3 resimden 2. Softball Glove String Replacement: adım 14, 3 resimden 3.
    • Push the string through the top hole on the right side of the middle finger.
  15. Softball Glove String Replacement: adım 15, 3 resimden 1. Softball Glove String Replacement: adım 15, 3 resimden 2. Softball Glove String Replacement: adım 15, 3 resimden 3.
    • Going around the back of the middle finger, insert the string into top hole on the right side of the middle finger.
  16. Softball Glove String Replacement: adım 16, 3 resimden 1. Softball Glove String Replacement: adım 16, 3 resimden 2. Softball Glove String Replacement: adım 16, 3 resimden 3.
    • Insert the string into the bottom right hole on the pointer finger.
  17. Softball Glove String Replacement: adım 17, 3 resimden 1. Softball Glove String Replacement: adım 17, 3 resimden 2. Softball Glove String Replacement: adım 17, 3 resimden 3.
    • On the backside, push the string through the bottom left hole on the middle finger and pull the string all the way through.
  18. Softball Glove String Replacement: adım 18, 3 resimden 1. Softball Glove String Replacement: adım 18, 3 resimden 2. Softball Glove String Replacement: adım 18, 3 resimden 3.
  19. Softball Glove String Replacement: adım 19, 3 resimden 1. Softball Glove String Replacement: adım 19, 3 resimden 2. Softball Glove String Replacement: adım 19, 3 resimden 3.
    • Insert the string into the top right hole on the pointer finger and pull the string all the way through.
  20. Softball Glove String Replacement: adım 20, 3 resimden 1. Softball Glove String Replacement: adım 20, 3 resimden 2. Softball Glove String Replacement: adım 20, 3 resimden 3.
    • Tie the end of the string close to the glove.
    • Cut off the excess string.
Sonuç
To remove a string from a softball glove, repeat these steps in reverse order.
Bir başkası bu kılavuzu tamamladı.
Christina Hart
331 İtibar
1 Kılavuz yazıldı
Ekip
1Rehber Yorum
Thank you so much for sharing this guide on softball glove string replacement! Your step-by-step instructions made it easy for me to replace the strings on my old glove and bring it back to life. Your expertise and generosity are truly appreciated!
Juliet Cyrus - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 35
Her zaman: 1,307
