Giriş
If your softball glove has a broken string, you need to restring it before you can play again. This guide will show you how to restring the fingers of your softball glove, making your glove as good as new. When restringing your glove, make sure the smooth part of the string is facing outwards. This is important so the string doesn’t slide or move around when you’re playing catch. Also, leather glove conditioner will make this process easier and smoother, but it is not required.
Neye ihtiyacın var
To remove a string from a softball glove, repeat these steps in reverse order.
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Thank you so much for sharing this guide on softball glove string replacement! Your step-by-step instructions made it easy for me to replace the strings on my old glove and bring it back to life. Your expertise and generosity are truly appreciated!
