Ana içeriğe geç
Sol Republic Deck Battery Replacement
Neye ihtiyacın var
  1. Sol Republic Deck Battery Replacement, Battery: adım 1, 1 resimden 1.
    • With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
  2. Sol Republic Deck Battery Replacement: adım 2, 1 resimden 1.
    • Use the screwdriver to unscrew 2 3.63mm Phillips #0 screws securing the plastic plate.
  3. Sol Republic Deck Battery Replacement: adım 3, 1 resimden 1.
    • Remove ribbon cable from the circuit board.
  4. Sol Republic Deck Battery Replacement: adım 4, 2 resimden 1. Sol Republic Deck Battery Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Unscrew five 3.6 mm Phillips #0 screws securing the circuit board.
    • The ribbon cables are adhesive attached to the case, use tweezers to VERY carefully pick them up. They will then lift up with the circuit board. Or desolder them at the bottom to separate from the circuit board.
    • Melt the solder with an iron and used the tweezers to pull the wire upright.
    • You can pull the circuit board up and away from the wires once the wires are pointed up.
  5. Sol Republic Deck Battery Replacement: adım 5, 1 resimden 1.
    • Unscrew eighteen 6.2 mm Phillips #0 screws and lift the black plastic plate from the case.
  6. Sol Republic Deck Battery Replacement: adım 6, 3 resimden 1. Sol Republic Deck Battery Replacement: adım 6, 3 resimden 2. Sol Republic Deck Battery Replacement: adım 6, 3 resimden 3.
    • Unscrew both 3.6 mm Phillips #0 screws holding the battery case to the back of the plastic plate.
    • Remove the battery from the battery case.
    • Original battery is ICR18650-30A. Its rated for 3000mAh, 6A continuous (2 C-rate).
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Ross Bolton
133 İtibar
1 Kılavuz yazıldı
Ekip
IUPUI, Team S3-G1, Baechle Spring 2017 IUPUI, Team S3-G1, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S3G1
3 Üyeler
3 adet Kılavuz yazıldı
10 Yorum
I appreciate the battery replacement for the deck,but what about battery replacement
For the deck ultra
chai4i - Yanıt
What type of battery is it?
Peter Perez - Yanıt
It's just a regular lithium ion 18650 battery 3.7v 3200-3500 mah. The deck ultra uses 2 of these
Aaron Linn - Yanıt
The wires which are blue and purple are connected to battery body if im not wrong
vineeth m -
After changing the battery my device is not switching on. Please help. I connected the charger the battery is charging... showing red.
vineeth m - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 29
Son 30 gün: 100
Her zaman: 8,033
