Ana içeriğe geç
Sol Republic Deck Bluetooth Button Replacement
Neye ihtiyacın var
  1. Sol Republic Deck Bluetooth Button Replacement, Bluetooth Button: adım 1, 1 resimden 1.
    • With plastic spudger wedge in between the top and bottom casings to force sepearation . Exposing the inside components of the Republic Deck.
  2. Sol Republic Deck Bluetooth Button Replacement: adım 2, 1 resimden 1.
    • Use the screwdriver to unscrew two 3.6mm Phillips #0 screws securing the plastic plate.
  3. Sol Republic Deck Bluetooth Button Replacement: adım 3, 1 resimden 1.
    • Remove the ribbon cable from the circuit board.
  4. Sol Republic Deck Bluetooth Button Replacement: adım 4, 1 resimden 1.
    • Plug in de-soldering kit and wait 3 minutes for the solder to heat up.
    • Use the tip of your soldering iron to heat the old solder unit and apply until it melts.
    • Remove speaker wires connecting the speaker to the circuit board.
  5. Sol Republic Deck Bluetooth Button Replacement: adım 5, 1 resimden 1.
    • Unscrew five 3.6 mm Phillips #0 screws securing the circuit board.
  6. Sol Republic Deck Bluetooth Button Replacement: adım 6, 1 resimden 1.
    • Unscrew fifteen 6.2mm Phillips #0 screws and lift the black plastic plate from the case.
  7. Sol Republic Deck Bluetooth Button Replacement: adım 7, 2 resimden 1. Sol Republic Deck Bluetooth Button Replacement: adım 7, 2 resimden 2.
    • Remove the three 3.6mm Phillips #0 screws.
    • Remove the circuit board containing the BlueTooth button.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Jonathan Holtman
368 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S3-G1, Baechle Spring 2017 IUPUI, Team S3-G1, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S3G1
3 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 6
Her zaman: 558
