Giriş
The LED lights on the speaker are what make the letters SOL light up multicolored when powering on the device. Within the device, these lights are held in place by a white strip attached to the motherboard.
Neye ihtiyacın var
Insert the tip of a plastic opening tool or spudger into the the middle groove along the edge of the device.
Insert another opening tool into the groove to hold the front plate up as you separate both plates on all sides. Use multiple opening tools to keep plates separated if necessary.
4 farklı kişi bu kılavuzu tamamladı.
